What Is the Percent Composition of Magnesium and Aluminum in the Alloy?
The discussion focuses on calculating the percent composition of magnesium and aluminum in a metal alloy based on the reaction with hydrochloric acid (HCl). A 1.00g sample of the alloy produces 0.0989g of hydrogen gas (H2). The balanced chemical equations provided are Mg + 2HCl -> MgCl2 + H2 and 2Al + 6HCl -> 2AlCl3 + 3H2. The participants emphasize the need to establish the moles of magnesium and aluminum in the alloy using stoichiometry and the mass of hydrogen produced.
  • Basic understanding of stoichiometry
  • Familiarity with chemical reactions involving acids
  • Knowledge of molar mass calculations
  • Ability to balance chemical equations
  • Calculate the molar mass of magnesium and aluminum
  • Learn about stoichiometric coefficients in chemical reactions
  • Explore the concept of percent composition in chemistry
  • Study the principles of gas evolution reactions
Chemistry students, educators, and professionals involved in materials science or chemical engineering who are interested in alloy composition analysis.
johndoe
A metal alloy consists of magnesium and aluminum.When a 1.00g sample of the alloy is reacted with excess HCl, 0.0989g of hydrogen gas forms. Calculate the percent composition of the alloy.
Ok I got the following balanced equations :
2Al + 6Hcl -> 2AlCl3 + 3H2
Can I say 1 mole of Mg reacts with 1 Mole of H2, with H2 being 1/4 of 0.0989g and
2 moles of Al reacts with 3 moles of H2, with H2 being 3/4 of 0.0989g?
No, you can't. That will happen only if you will know you have mixture of 1 mole of Mg and 2 moles of Al, you don't know neithe rhow many moles of both nor in what ratio you have.
Write two equations - one for sum of masses of metals, one for sum of numbers of moles of metals. The latter will use moles of hydrogen produced and stoichiometry of the reactions provided.
9K
11K
