What is the solution to the Doppler Effect and Fire Truck Homework?
The problem involves understanding the Doppler Effect as it relates to the sound of a fire truck's siren. The original poster presents a scenario where the frequency of the siren changes as the truck approaches and then recedes, and they seek to determine the time it takes for the truck to reach a fire located 2.5 km away, assuming a constant speed.
  • Participants discuss the need to calculate the truck's velocity based on the Doppler shifted frequencies. There is mention of two separate Doppler effects: one for the approaching truck and one for the receding truck. Questions arise about which frequency to use as the stationary frequency and how to approach solving for the unknowns involved.
The discussion is ongoing, with participants providing guidance on interpreting the problem and suggesting that the original poster clarify the meaning of the variables in the relevant equations. There is recognition of the need to establish the source frequency and the truck's velocity, but no consensus has been reached on the specific approach to take.
Participants note the known values, such as the speed of sound, and emphasize the importance of understanding the relationship between the observed frequencies and the stationary frequency. There is an acknowledgment of the two unknowns that need to be solved for in the context of the Doppler effect.
MaluDude
Hearing the siren of an approaching fire truck, you pull over to the side of the road and stop. As the truck approaches, you hear a tone of 470 Hz; as the truck recedes, you hear a tone of 400 Hz. How much time will it take the truck to get to the fire 2.5 km away assuming it maintain a constant speed?
f'=f(v/(v+(or minus) vs))
yf=yi+vit+1/2at2
I tried to plug in 470 and 400 for f', but I did not know what to do after that.
Your first relevant equation relates the true frequency f to the doppler shifted frequency f' that results from the object moving toward or away from you at a speed v. To find the time it takes for the truck to travel, we're going to have to calculate its velocity v.
I would first think about the situation presented in the problem and how to apply your first relevant equations. Be sure to first understand the meaning of the variables in that equation. If f in the equation is the stationary frequency of the noise, do we want to plug either 400 or 470 into f?
so there are 2 separate doppler effects here - one when the truck is appraoching, one when it is receding
so you need to solve for 2 unknowns, true fs (source frequency) and the velocity
Why would you want to put those 2 values into your stationary f value? Wouldn't you want to include those values for the changed f-values? Also couldn't you say that the speed of sound is just 334?
you have to ask yourself what you are trying to find... the truck velocity
unknowns:
source frequency (somewhere between 400 & 470) and source velocity (ie truck speed)
knowns:
spped of sound
you know the doppler changed frequencies for the approaching truck & receding
you should be able to write a doppler equation with the 2 unknowns in each case, and solve for the truck velocity...
  • · Replies 18 ·
14K
