Mass falling on a vertical spring
A 195 g block dropped onto a vertical spring with a spring constant of 1.6 N/cm compresses the spring by 14 cm, performing 0.26754 joules of work against gravity and -1.568 joules of work by the spring force. The speed of the block just before impact is calculated to be 3.652 m/s. When the impact speed is doubled, the maximum compression of the spring can be determined using the conservation of energy principle, where the kinetic energy of the block is converted into potential energy in the spring.
  • Understanding of Newton's laws of motion
  • Knowledge of spring mechanics and Hooke's Law
  • Familiarity with energy conservation principles
  • Basic algebra for solving equations
  • Study the conservation of mechanical energy in spring systems
  • Learn about Hooke's Law and its applications in physics
  • Explore the relationship between kinetic energy and potential energy
  • Investigate the effects of varying mass and spring constants on compression
Physics students, educators, and anyone interested in understanding the dynamics of mass-spring systems and energy transformations in mechanical systems.
bikerboi92
A 195 g block is dropped onto a relaxed vertical spring that has a spring constant of 1.6 N/cm. The block becomes attached to the spring and compresses the spring 14 cm before momentarily stopping.
(a) While the spring is being compressed, what work is done on the block by the gravitational force?
.26754 joules
(b) While the spring is being compressed, what work is done on the block by the spring force?
-1.568 joules
(c) What is the speed of the block just before it hits the spring? (Assume that friction is negligible.)
3.65212969 m/s
(d) If the speed at impact is doubled, what is the maximum compression of the spring?
This is the only part that I can not get
You can count the speed of the block at impact. You double it, which essentially gives a new value for its kinetic energy. This kinetic energy (and some potential energy as the spring is compressed, the block comes closer to the ground, i.e. it loses potential energy) is then transformed into potential energy in the spring. From that you can get the maximal compression.
Potential energy in spring=0.5kx^2
where k is the spring constant and x is the compression. Maybe that helps a little bit?
I'm you didn't understand Ofey, its pretty simple really. You know that energy cannot be created or destroyed, only transferred. When a mass is dropped onto a spring, potential energy is converted to kinetic.
[tex](mgz)_1 = \left(\frac{1}{2}m v^2\right)_2[/tex]
At the bottom of the fall, the kinetic energy is converted into potential energy in the spring.
[tex]\left(\frac{1}{2}m v^2\right)_1 = \left( \frac{1}{2}k z^2\right)_{spring}[/tex]
Keeping the z notation. The question is if V = 2V, find z.
*note for simplicity I have neglected potential energy conversion during the spring compression as Ofey mentioned. For complete accuracy, you should take into account (i.e. however this might be an iterative process since you don't know the compression beforehand).
  • · Replies 18 ·
  • · Replies 58 ·
