Why Is the Frobenius Method's Second Solution Valid?
  • Context: Graduate
  • Thread starter Thread starter matematikawan
    Frobenius Method
The Frobenius method's second solution for the differential equation \(x^2y'' + xp(x)y' + q(x)y = 0\) is valid when the indicial equation has equal roots \(\lambda = \lambda_1 = \lambda_2\). The first solution is given by \(y_1(x) = x^{\lambda_1}\sum a_n x^n\). The second solution can be expressed as \(y_2(x) = y_1(x)\ln x + x^{\lambda_1}\sum b_n x^n\). The method to compute \(y_2\) involves differentiating \(y_1\) with respect to \(\lambda\) at \(\lambda = \lambda_1\), as stated in the Schaum Outline Series in Differential Equations.
  • Understanding of regular singular points in differential equations
  • Familiarity with the Frobenius method for solving differential equations
  • Knowledge of indicial equations and their roots
  • Basic calculus, particularly differentiation techniques
  • Study the derivation of the Frobenius method in detail
  • Learn about the Lagrange reduction of order technique
  • Explore Hildebrand's "Advanced Calculus for Engineers" for deeper insights
  • Review the Schaum Outline Series in Differential Equations for practical examples
Mathematicians, engineers, and students studying differential equations, particularly those interested in advanced solution techniques and the Frobenius method.
matematikawan
Assume that x=0 is a regular singular for x2y" + xp(x)y' + q(x)y = 0
and the indicial equation has equal roots [tex]\lambda = \lambda_1 = \lambda_2[/tex]
The first solution is alway known to be of the form [tex]y_1(x) = x^{\lambda_1}\sum a_n x^n[/tex]
Although tedious, I know how to obtain the second linearly independent solution using the Lagrange reduction of order, y2(x) =u (x)y1.
I think it is well known that the second solution will be of the form
[tex]y_2(x) = y_1(x)lnx + x^{\lambda_1}\sum b_n x^n[/tex]
The book I'm refering, Schaum Outline Series in Differential Equation (cheap and direct to the method :smile: ) gives the following method to compute y2.
[tex]y_2(x) = \frac{\partial y_1(x,\lambda)}{\partial\lambda} |_{\lambda=\lambda_1} \\\ (*)[/tex] .
As you all know the book never proved any of their theorem/method.
My question is why (*) is a solution for the DE? Any proof for it?
I don't remember the method well enough to do this for you but I think its sortof similar to how you prove that a linear constant coefficient equation with a repeated root of the characteristic polynomial will have a second solution given by t times the first. I know I have seen a very good exposition on this topic in Hildebrand's Advanced Calculus for Engieneers. I would highly recommend that book for a lot of stuff and that section was very clear - but I didn't work it through well enough to internalise it and be able to answer your question from the top of my head.
Thanks b17m4p.
There is a copy in our library. I will try to get it. But it looks quite an old edition 1958 ?
QA303 HIL 1949
Advanced calculus for engineers
Hildebrand, Francis Begnaud.
Englewood Cliffs, N.J. : Prentice-Hall, [1958]
If only I have the note with a click of mouse! :smile:
Wikipedia ? MIT courses ?
