Good glue/adhesive to bond a 30 micrometer kapton foil
  • Thread starter Thread starter Rajini
    Bond
The discussion revolves around finding an appropriate adhesive to bond a 30 micrometer kapton foil to a copper metal surface, specifically for use in a cryostat environment at temperatures ranging from 4.2 K to room temperature. The bonding must be strong enough to withstand high vacuum conditions and liquid helium flow, with curing limited to room temperature.
  • Experimental/applied
  • One participant inquires about suitable adhesives for bonding kapton foil to copper, emphasizing the need for strength at low temperatures and high vacuum conditions.
  • Another participant suggests that most glues would work down to 4.2 K, noting that concerns typically arise from out-gassing or thermal conductivity, which may not be critical in this case.
  • A specific adhesive, Eccobond, is recommended by one participant for its thermal conductivity, alongside a mention of Stycast, although it is described as messier to use.
  • A participant clarifies their application, describing a hollow copper rod with holes for X-ray passage, and reiterates the need for strong bonding under specified conditions.
  • Questions arise regarding the force required for bonding, with calculations presented to determine if a weight of 155 grams is sufficient to meet the adhesive's manual requirements.
  • Another participant confirms the calculations regarding the necessary weight to apply force for bonding.
Participants express varying opinions on the types of adhesives suitable for the application, with no consensus reached on a single best option. There is also a discussion on the bonding force required, with some calculations confirmed but no definitive agreement on the implications for the adhesive's effectiveness.
Participants mention specific conditions such as the need for room temperature curing and the absence of concerns regarding thermal or electrical conductivity, which may limit the applicability of certain adhesives.
Rajini
Hi PF members,
Is there any good glue/adhesive to bond a 30 micrometer kapton foil to copper metal...
The bonding should be strong enough to withstand liquid helium temperature (my working condition is 4.2 K to room temperature)...I can cure only at room temperature.
or
anyone have some experience with
3M scotch-weld epoxy adhesive 2216 B/A please share your experience..
thanks you for your reply.
I don't quite understand what you are trying to do; are you simply trying to glue kapton tape to copper? No other requirements?
Just about any glue will work reasonably well down to 4.2K; the main reason why people use "special" glues when working at low temperatures is either because they are worried about out-gasing (since low-temperatures experiments are often done in vacuum) or because they need good thermal conductivity, but the latter is rarely a problem if the temperature is as high as 4.2K.
I personally tend to use something called Eccobond which is a two-component epoxy and has reasonably good thermal conductivity.
And of course I also use Stycast (just like everyone else), but that is a bit messier to use.
I will explain my situation clearly (i want to make a window for my cryostat!)...Think i have a hollow copper rod (2 cm X 2 cm) and length say 30 cm. Now on the surface of the hollow rod i have two holes diametre of 1 cm. X-ray can pass through one hole and come out from the other hole. I want to glue/bond/cover the two holes using kapton foil (30 micrometer thick). Along the path of X-ray i keep my sample, which will be at liquid helium temperature. Outside the rod there will be high vacuum and inside constantly liquid helium will be flowing just to cool the sample..
So bonding must be good at 4.2 K also withstand high vacuum..(i don't care about thermal or electrical conduction properties or doesn't matter about chemical resistance properties)..
PS: I can only cure at room temperature..and i can only glue from outside surface of the rod.
Another question (this is not so important but i like to know..)...in the glue manual it's mentioned that i should apply force (~2 psi=2 pound/inch^2) to bond, and wait for 5 days...but my surface area is ~2 cm X 2 cm...so 155 grams weight should be enough..i am correct..?
2 cm x 2 cm = 4 cm^2 = 0.62 sq inches
0.62 x 2 = 1.24 pounds = 0.562 kg.
Yes..thanks..
