Does the concept of force apply to photons without a measurable mass?
  • Context: Graduate
  • Thread starter Thread starter nelsyeung
    Mass Photons
The discussion revolves around the applicability of the concept of force to photons, particularly in the context of their lack of measurable mass. Participants explore the implications of gravitational effects on light, the relationship between mass and gravity, and the theoretical frameworks of Newtonian gravity and General Relativity (GR).
  • Some participants suggest that if photons have no mass, it raises questions about how gravity can bend light, particularly near massive objects like black holes.
  • Others argue that in Newtonian gravity, the acceleration due to gravity is independent of mass, and in GR, particles follow geodesics, which also does not depend on mass.
  • A participant proposes that photons might have an extremely small mass that is currently unmeasurable.
  • There are discussions around the implications of Einstein's equation \(E=mc^2\) and how it relates to the mass of photons, with some suggesting that mass and energy are equivalent in the context of gravity.
  • Concerns are raised about the implications of massless particles and how they can still be affected by gravity, leading to confusion about the relationship between mass, energy, and gravitational effects.
  • Some participants express skepticism about the idea that a box filled with photons could have equivalent mass to a box of normal matter, questioning the experimental testability of such concepts.
  • There is a discussion about the dynamics and kinematics of gravity, with one participant explaining that while mass affects the force experienced by an object, massless particles can still experience acceleration due to gravity.
Participants generally do not reach a consensus, as multiple competing views remain regarding the nature of photons, the concept of mass, and the implications of gravity on light.
Participants express uncertainty about definitions of mass, the implications of relativistic effects, and the measurement of gravitational forces on massless particles. The discussion highlights the complexity of reconciling different theoretical frameworks.
nelsyeung
Been thinking about this for sometimes now, most people say photons doesn't have a mass, and in theory since photons travel the speed of light then it must either have no mass or always been traveling at the light. But if a photon doesn't have a mass then how can things such as black hole or even just a star with high enough gravitational force to bend light. My personal thinking is that photons might have a mass but so small that we can't measure, but seriously not sure. :P
Science news on Phys.org
In Newtonian gravity a particle's acceleration due to gravity is independent of its mass. In GR particles follow geodesics, so the motion is also independent of mass.
nelsyeung said:
Been thinking about this for sometimes now, most people say photons doesn't have a mass, and in theory since photons travel the speed of light then it must either have no mass or always been traveling at the light. But if a photon doesn't have a mass then how can things such as black hole or even just a star with high enough gravitational force to bend light. My theory is that photons might have a mass but so small that we can't measure.
You may want to start by reading the FAQ in the General Physics section, and definitely before you venture into making your own personal theory.
Zz.
Photons in my perspective, is the light or radiation emitted by something like a light bulb to our Sun. The smallest mass that we have discovered is the electron that orbits the nucleus of an atom. Anything can be measured in a scientific way, big or small. They may be exact or an approximation to the true value. There are exceptions, but photons are like radiation like the visible light that we see.
I kinda understand what you are saying but, I don't quite get then how can gravity be calculated using gm/r^2
and also during the relativistic effect a particle will increases mass dramatically which causes the acceleration to slow down, so i thought there must be a clear link between mass and gravity.. :( hmm..
what do you mean by mass?
i think
E=m.c2
gives the permission to think about the mass of a photon,but rest mass,is not !
there is a difficulty m=m0/[tex]\gamma[/tex]
where [tex]\gamma[/tex]=[tex]\sqrt{}[/tex]1-v2/c2
if m0=/=0
then m=infinity for v=c
i think mass and energy both are same for gravity ...
i think
E=m.c2
if m0=/=0
I really don't understand from m=m0/[tex]\gamma[/tex]
m0=/=0, surely since m0 is on the top of fraction and its 0; the answer must be 0. How did you get infinity?
But yes its true that mass must be either infinite or 0 to actually move at the speed of light, that's why it requires infinite amount of energy to do that.
But then again I really don't understand how can gravity affect light.
E=mc^2 is just that, energy and mass is the same thing.
You don't notice any difference between effective mass and rest mass, its impossible to determine if you trapped 1kg worth of photons within a totally reflective box or just 1 kg of normal matter.
And on top of that photons also creates gravity fields around themselves which is obvious since they are effected by the fields, otherwise we could create physical absurdities.
Don't worry now, I realize that I forgotten theory of relativity when I thought of this question.
But I don't think light does create a gravitational field though, since if the mass of a photon is 0 then gm/r^2 must also equal 0
While energy and mass can be equivalently converted between each other, can someone please confirm this statement true? If we had a internally reflective box filled with [tex]c^2 J = 9.10^{16} J[/tex] of photon energy and another box with 1kg of mass, would these 2 boxes now be equivalent in mass? I am skeptical about this so can someone please confirm/disprove this.
That is theoretically correct, but since there is no such thing as a perfectly reflective box it is not experimentally testable.
That is a common misconception that I am always fighting. Let's split our thoughts about gravity into the dynamics (i.e. the forces) and the kinematics (i.e. the motion). And for simplicity let's start with Newtonian gravity and only consider cases where M>>m (i.e. a small particle in the gravitational field of a big planet).
Dynamics: The particle is acted on by a force F = GMm/r². The mass of the particle does determine the force on the particle, so a particle with m=0 should have no force. But how do we measure this force? It turns out that this force is impossible to measure directly, we can use a scale to weigh the object, but what this actually measures is the normal force not the force of gravity. Since we cannot measure this force then how do we know it is given by F = GMm/r²? We know because of the kinematics, i.e. on a scale we measure the normal force, the object is kinematically stationary, so there must be a gravitational force cancelling out the normal force.
Kinematics: The particle undergoes an acceleration of a = GM/r² if it is free to move. So a free particle of m=0 should (according to Newtonian theory) undergo the same acceleration as any other free particle. We can measure this acceleration directly, so in some sense, this acceleration is the primary effect of gravity and the force is a secondary or presumed effect. Now, since we can directly measure the acceleration of a massless particle let's work backwards and see what the force should be. We can use F = ma = 0 GM/r² = 0. So from the kinematics, despite the fact that the particle is accelerating, the force is 0, i.e. it does not take any force to accelerate a massless particle, they have no inertia. So this kinematic result is consistent with the dynamics above.
GR: Now, there is one big problem with all of the above, and that is that all massless objects travel at c where relativistic considerations are obviously important. So it turns out that the Newtonian approximation is off by a factor of 2. I don't want to get too far into the details, but in GR gravity is not considered a real force at all. Instead, the observed kinematics are attributed to curved spacetime rather than to any force. In other words, free particles, like a satellite, travel in (locally) straight lines called geodesics through a (globally) curved spacetime. There is no force of gravity, so there really are no dynamics, and the path of the particle depends on the curvature of the underlying spacetime and not on the mass of the particle. Therefore, massless free particles also travel on these geodesics so their path is (globally) curved just like everything else. Again, the kinematics do not depend on the mass of the particle.
Its because that formula is wrong though unless you consider effective mass, and photons got effective mass. (Effective mass is just another word for total energy contained)
As I said energy and mass is indistinguishable except that energy is moving and mass is standing still.
if rest mass m0 not equals to zero
so if v=c
then m0 must be zero
that's why i write m0=0 for photon
look at the equation E2=p2 c2+m02c4
if m0=0 & E not equals to zero
then p=momentum not equals to zero
so relativistic momentum can be non-zero even for a zero rest mass
Ok now leads me to a few more questions:
1. If gravity is considered as a force that pulls bodies together, but can it be considered as a force that bend space-time, which then allows bodies to fall into each other?
2. Many people talked about effective mass and rest mass, but since photons or light are always traveling, so it most of the time are exerting effective mass, can we not just ignore rest mass?
3. I know that photons does have momentum, hence the maths and experiment. If a massless object have acceleration and momentum, but doesn't have force, then does this formula still applies? F = [tex]\frac{dp}{dt}[/tex], so if there is a momentum over time, then there's a force. This is not a really good question, sorry I am not very good in physics. :(
to
nelsyeung,
"But I don't understand the last piece of maths"
which one?
sanjibghosh said:
to
nelsyeung,
which one?
Oh sorry it suppose to be a statement that I don't understand does F = dp/dt still applies
Have you even read the FAQ that has been suggested to you? There are at least TWO separate entries in there that are relevant here that might have easily answered your original question. If you start from there and elaborate on which part you do not understand, rather than keeping on making up a rather vague starting point, it might be easier for the rest to address the problem you are having in understanding all this.
Zz.
That one applies perfectly, however usually you won't see it as a force acting on the light but instead the light acting with a force on other objects except when dealing with gravity.
Maxwell in about 1871 deduced that electromagnetic radiation exerted radiation pressure on any surface, and in 1901 Nichols (at Dartmouth) verified it experimentally to 1 or 2% accuracy by reflecting light striking a mirror on a radiometer in a vacuum. The radiation pressure of light is equivalent to momentum transfer. Since light in vacuum always travels at the speed of light in any inertial coordinate system, it is nonsensical to talk about photon rest mass. But if you count photons (quantize light), you can deduce the amount of momentum transfer per photon. So if a photon has energy E = h*w/(2pi), (Planck's constant times frequency) its momentum is E/c or h*w/(2c*pi). But E/c is the same as the momentum of an extremely relativistic particle wth total energy E (consider relativistic electron or neutrino beams, where the rest mass is neglegible). Also think about using a light beam as (very inefficient) thrust for interplanetary vehicle.
Photons falling in a gravitational field gain energy (and momentum), as proved by the famous Mossbauer Effect experiment at Harvard (Purcell).
That is basically the definition of force- it always applies.
  • · Replies 19 ·
  • · Replies 31 ·
  • · Replies 19 ·
  • · Replies 27 ·
