Technique in Sequence: How Can I Use Formulas to Find the Next Terms?
  • Context: High School
  • Thread starter Thread starter sarah22
    Sequence
The discussion revolves around finding formulas for various numerical sequences. Participants explore different methods and approaches to derive these formulas, focusing on sequences that exhibit polynomial or exponential behavior. The scope includes conceptual reasoning and mathematical reasoning related to sequences.
  • Some participants suggest using differences or ratios between successive terms to identify patterns in the sequences.
  • One participant proposes a formula for the second sequence as (11)(2^n) - 3, based on observed differences.
  • Another participant mentions using the Lagrange interpolating polynomial for polynomial sequences.
  • There is a discussion about adjusting the exponent in the formula for the third sequence to account for the starting index.
  • One participant describes a technique of subtracting terms to find a pattern, but faces challenges in correctly identifying the differences.
  • Some participants express uncertainty about the correctness of their approaches and seek clarification on their reasoning.
  • There is a mention of a potential exponential growth in one of the sequences, but the exact nature of the growth remains unclear.
Participants do not reach a consensus on the correct formulas for the sequences, and multiple competing views and methods are presented throughout the discussion.
Some participants struggle with the initial conditions of the sequences and the implications for their proposed formulas. There are unresolved questions about the correctness of certain calculations and the assumptions underlying the proposed methods.
sarah22
Can anyone help me how to get the formula fast?
Example:
1) 2, 4, 8, 16 n=1
Answer: 2^n
Problem:
1) -2, 2, 22, 122... n=0
2) 8, 19, 41, 85, 173, 349... n=1
3) -1/3, 1/2, -3/4... n=1
I am really inexperienced at sequences, especially when it comes to finding formulas; so please excuse my help as it could be a very unconventional way to approach the problems.
1) I don't know
2) I noticed that the difference between each term started with 11, and doubled each time so I assumed the formula would be in the form of [tex]y=a.2^{x+b}+c[/tex] and after some guessing, I let a=11 because the first difference was 11... edit: broke a rule.
3) The sequence is being multiplied by [tex]\frac{-3}{2}[/tex] since [tex]\frac{S_2}{S_1}=\frac{S_3}{S_2}=\frac{-3}{2}[/tex] but I'm unsure where to go from there :blushing:
Problem:
Hi sarah22! :smile:
In problems like this, the methods that usually work are to write the numbers on one line, and either the differences or the ratios between successive numbers on their next line …
then do it again and again until you get a line that's easy (like 2 2 2 2… or 1 3 5 7 …) …
in at least one of your three problems, you'll have to use both differences and ratios (on different lines, of course) :wink:
edit: broke a rule.
Mentallic, please do not give complete answers!
Problem:
If the formula is a polynomial, try the Lagrange interpolating polynomial.
Ok I got number 2 and some in 3. I'm sorry I didn't put where the n starts. I'll edit my first post.
2) (11)(2^n) -3
3) (-1/3)(-3/2)^n if n = 0. but it starts with 1 so how can I do it?
I still don't get the other number. OMG. I'm doom.
@Mentallic
Ok I got some in number 3.
@tiny-tim
Yeah I'm doing that but still I don't get number 1 and 3.
@bpet
Can you teach how is it done?
Thanks everyone for helping me. :wink:
Hi sarah22! :wink:
Try 1) … write out the differences and you get … ? :smile:
Ok here is it. I still don't get it. Oh no! I don't want to fail.
0 -(2) ?(n) n=0
4 -(2) 4(n) n=1
24 -(2) 12(n) n=2
144-(2) 48(n) n=3
sarah22 said:
0 -(2) ?(n) n=0
4 -(2) 4(n) n=1
24 -(2) 12(n) n=2
144-(2) 48(n) n=3
eugh! you're adding! why are you adding? :cry:
take the differences :smile:
You want to make the first term to the power of 0, [tex](-1/3)(-3/2)^0[/tex]
then the next term to the power of 1, [tex](-1/3)(-3/2)^1[/tex]
but for the first term n=1 and for the second, n=2.
Fiddle with the exponent a bit, I'm sure you'll get it :wink:
For #3, when you take the differences between the terms, notice the rate at which the numbers are rising. Is it by a multiple, a ratio, an exponential..?
Ok, I got a technique from my friend. I'll just subtract the first term from the next then see how is it made.
2-2, 22-2, 122-22
0, 20, 100So on each term it is increase 5 times the previous.
(5^n)
1, 5, 25, 125
so to make the formula correct. You need to minus it by 3. that's it.
My professor didn't teach most of this technique. I really hate her!
Yeah, I'm a bit crazy the time I posted it. lol. You just need to subtract n in 1.
(-1/3)(-3/2)^n-1
I dunno. Is it exponential because I raise it by n?
2-2, 22-2, 122-22
0, 20, 100
did you do this yourself, or just copy it? either way you got it wrong :redface:
it's 2 - (-2) = 4, not 0 …
and how did you get
from 0, 20, 100 ?
uhhh? where does the 3 come from? and what do you mean anyway?
tush, sarah22 … that's no way to talk about your nice teacher! :rolleyes:
anyway, show us the formula, just to make sure you've got it now. :smile:
2-2, 22-2, 122-22
0, 20, 100
So even though you got the difference between the first and second term wrong, you found the rate of increase correctly. Handy :smile:
sarah22 said:
(5^n)
1, 5, 25, 125
that's it? nearly. Test your formula [tex]S_n=5^n-3[/tex] and you'll see what you're missing.
(-1/3)(-3/2)^n-1
Yes :smile:
