Solve Normal Distrib. Homework: X mean 10, stdev 2, P(X<X<10)=0.2
The problem involves a normally distributed variable X with a mean of 10 and a standard deviation of 2. The goal is to find the value of x such that the probability P(x < X < 10) equals 0.2.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the relationship between the probabilities and z-scores, with some attempting to derive the value of x using standard normal distribution tables. There are questions about the correctness of z-values and the interpretation of probabilities related to areas under the curve.
Participants are actively engaging with the problem, exploring different interpretations of the z-scores and the corresponding probabilities. Some have provided alternative values for z and are questioning the assumptions made in earlier calculations. There is no explicit consensus yet, but several productive lines of reasoning are being explored.
There are indications of confusion regarding the use of standard normal distribution tables and the interpretation of probabilities as areas under the curve. Participants are also discussing the implications of positive and negative z-values in relation to the problem.
6021023
Assume X is normally distributed with a mean of 10 and a standard deviation of 2. Determine the value for x that solves P(x < X < 10) = 0.2
P(X < x) = P(Z < z) = P(Z < (x - mean)/stdev)
P(X < 10) - P(X < x) = 0.2
P(Z < (10-10)/2) - P(Z < (x-10)/2) = 0.2
P(Z < 0) - P(Z < (x-10)/2) = 0.2
0.5 - P(Z < (x-10)/2) = 0.2
P(Z < (x-10)/2) = 0.3
(x-10)/2 = 0.617911
x - 10 = 1.235822
x = 11.235822
The answer doesn't make sense. x is supposed to be smaller than 10.
P(x < X < 10) = 0.2 <==> P(z < Z < 0) = 0.2, where Z is the usual standard normal distribution.
From a table of areas under the standard normal distribution, I find a z value of about -.525.
z = (x - 10)/2 ==> 2z = x - 10 ==> x = 2z + 10
Substituting the value of z = -.525 that I found earlier, I get an x value of 8.95.
So, P(8.95 < X < 10) = 0.2, approximately
So when I tried to solve the problem, what did I do wrong?
Your error is in the next line. Your z-value (which is what you're getting from the table) should be negative. Apparently you picked the wrong value. If you recall, my value was -.525.
6021023 said:
(x-10)/2 = 0.617911
x - 10 = 1.235822
x = 11.235822
In working these kinds of problems, I find that it is much easier to switch right away to a probability involving z (or t, or whatever), do my calculation and look up the value, and then change back to the original random variable X.
Mark
I checked my book again, and it shows that the z value for 0.3 is 0.511967. Is that incorrect?
I think you might be using your table incorrectly. The table I used has probability values (areas under the bell curve) only to 4 decimal places, but that's just a detail.
For z = 0.3, my table shows a probability of 0.6179.
For z = 1.0, it shows 0.8413.
Yes, I was looking at the table incorrectly. For z = 0.3, the probability is 0.617911. This is similar to what you got and it's what I originally found.
So for z = 0.3, if the probability is 0.617911, then shouldn't the following steps be correct?
(x-10)/2 = 0.617911
No. Since the probability P(Z < zp) = 0.3 (zp is the particular z value you're looking for), you have to be looking for a z-value in the left half of the bell curve. IOW, for negative values of z. Keep in mind that for z = 0, half of the area is to the left, and half to the right.
If you're not working with a sketch of the bell curve, with the area you want shaded in, you should be.
Why does it have to be in the left half of the curve? 0.3 is still a positive number. What part in my answer should I change, and how should I change it?
Because you want P(Z < zp) = 0.3. This probability represents the area under the bell curve from z = [itex]-\infty[/itex] to some z value to the left of zero. If the inequality went the other way, as in P(Z > zp) = 0.3, you would be looking for a positive z-value.
If you had to solve P(Z < zp) = .5, what would you get for what I'm calling zp?
For P(Z < zp) = .5
zp = 0.691462
No. zp = 0
I don't think you get the connection between probability and area under the bell curve. For example, P(-1 < Z < 0) represents the area under the curve between z = -1 and z = 0. The area/probability is about .34.
I thought that the probability is the area under the curve.
Although now I can see how you're using the table. So I guess for P(Z < zp) = .3, then zp = -0.53 or -0.52?
Yes, probability is the area under the curve, but if you have a probability like P(Z< a), the probability is the area under the curve between z = [itex]-\infty[/itex] and z = a. If it's a probability like P(a < Z < b), it's the area under the curve between z = a and z = b. Finally, for a probability like P(Z > b), it's the area under the curve from z = a to z = [itex]\infty[/itex].
As for the values, if you recall, I first said that it was about -.525.
What I was asking is how do you know if the answer is -0.53 or -0.52? The z value doesn't correspond to one of those numbers but rather a number in between. Which value do I use, or does it not matter?
Since the probability I was looking for was about midway between those numbers, I interpolated to get -.525, which is a better choice than either -.52 or -.53.
If you want to find out more about this, do a search on "linear interpolation."
I think I've pretty much got this problem figured out now. Thanks!
  • · Replies 18 ·
21K
