Deriving arccos from arcsin using trigonometric identities
  • Thread starter Thread starter guildmage
    deriving
The discussion revolves around the relationship between the inverse trigonometric functions arccos and arcsin, specifically the assertion that arccos z can be expressed in terms of arcsin z with an additional periodic component. The subject area includes complex variables and trigonometric identities.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants explore the identity arccos z = π/2 - arcsin z and question its validity, particularly regarding periodicity and the implications of negative arguments in arcsin. There is also discussion about the derivation of arcsin(-z) and its relationship to arcsin(z).
The discussion is ongoing, with some participants questioning the original assertion and suggesting counterexamples. There is a recognition of potential errors in the derivation and a suggestion to clarify the problem with the professor. Multiple interpretations of the problem are being explored.
Participants note that the problem is part of a homework assignment in a Complex Variables course, and there is uncertainty about the correctness of the original statement. The definition of logarithmic functions and their implications for the multi-valued nature of certain expressions are also under consideration.
guildmage
I want to show that:
[tex]\arccos \,z= \left( -1 \right) ^{n+1} \arcsin \,z+\pi/2\, +n\pi[/tex]
There is a trigonometric identity that says
[tex]\arccos \,z= \pi/2\, -\arcsin \,z[/tex]
So far, I have come up to this
[tex]\arccos\,z=\pi/2\, -{\it i}\log\ \left( -iz+\sqrt {1-{z}^{2}} \right)[/tex]
What is left to show is that
[tex]\arcsin\, \left( -z \right) = \arcsin\,z[/tex]
My plan is to add the periodicity (is that the term?) later on since
[tex]-\cos\,z= \cos\ \left( z+\pi \right)[/tex]
Why would you want to show this?...It isn't true!
For example, for n=2 you have [tex]\left( -1 \right) ^{n+1} \arcsin \,z+\pi/2\, +n\pi =- \arcsin \,z+\pi/2\ +2\pi=\arccos \,z +2\pi \neq \arccos \,z[/tex]...
Not sure what you did to get to this point, but you have a sign error; you should have
[tex]\arccos\,z=\pi/2\, +{\it i}\log\ \left( -iz+\sqrt {1-{z}^{2}} \right)[/tex]
Again, why would you want to show this? The fact that [itex]\sin(-x)=-\sin(x)[/itex] should tell you that it's not true.
Is this part of a larger problem? What is the original question?
This problem is not part of a bigger problem:
I have seen a similar computation http://math.fullerton.edu/mathews/c2003/ComplexFunTrigInverseMod.html" .
I am not sure though how [tex]\arcsin\, \left( -z \right) = \arcsin\,z[/tex] was derived.
That link contains a typo (at least one): [itex]\arcsin(-z)=-\arcsin(z)\neq\arcsin(z)[/itex]...plug in some numbers into your calculator if you don't believe me.While your at it, plug some numbers into the equation your trying to prove...you'll find that it isn't true (except for n=0 of course)
Let's say you're right. How then do I resolve this? Do I provide a counterexample instead of proving it? The problem was explicit in saying that I should prove it.
This problem is given by my professor in Complex Variables which I am taking under an MS Math degree program.
Provide a counter example...say z=0 and n=1 for example...
Are you sure you weren't asked to show
[tex]\cos\left(\left( -1 \right) ^{n+1} \arcsin \,z+\pi/2\, +n\pi \right)=z[/tex]
Because that actually is true...the reason that you can't just take the arccos of both sides is that arcos always returns the principle value, so arcos(z) is always between 0 and 2pi, while [itex]\left( -1 \right) ^{n+1} \arcsin \,z+\pi/2\, +n\pi[/itex] need not be...this is why what you say you are trying to prove, is not true.
I'm sure that the problem I posted was the original problem.
Thanks for your advice. I'll ask my professor about it.
I just thought, isn't it that since that arccos is expressed in terms of log, then it should be multiple-valued since log is?
Since when is Log multiple valued? :confused:
ArcCos and Log are both defined in a way that makes them single valued.
This is our definition:
[tex]\log \,z= \ln \, \left| z \right| +i Arg \left( z+2\,n\pi \right)[/tex]
as opposed to
[tex]Log \,z= \ln \, \left| z \right| +i Arg z[/tex]
So log here becomes multiple valued, whereas Log is not.
  • · Replies 105 ·
13K
  • · Replies 17 ·
