Force and Motion, I'm a bit confused on how to approach this.
The discussion focuses on resolving two forces, F1 and F2, to find the resultant force's components and magnitude. F1 has a magnitude of 8.60 N at an angle of 63.0 degrees above the negative x-axis, while F2 has a magnitude of 6.00 N at an angle of 53.2 degrees below the negative x-axis. The user initially considered using trigonometric functions to break down the forces into their x and y components. Ultimately, the user successfully solved the problem, indicating a resolution of confusion regarding the approach.
  • Understanding of vector resolution in physics
  • Knowledge of trigonometric functions, specifically sine and cosine
  • Familiarity with force diagrams and components
  • Basic algebra for solving equations
  • Study vector addition and the parallelogram law of forces
  • Learn how to apply trigonometric functions to resolve forces into components
  • Explore the concept of resultant forces in two dimensions
  • Practice problems involving forces at angles to reinforce understanding
Students studying physics, particularly those learning about forces and motion, as well as educators looking for examples of vector resolution in force problems.
alexas
Two forces, F1 and F2, act at a point. F1 has a magnitude of 8.60 N and is directed at an angle of 63.0 (DEGREES) above the negative x-axis in the second quadrant. F2 has a magnitude of 6.00 N and is directed at an angle of 53.2 (DEGREES) below the negative x-axis in the third quadrant.
What is the x component of the resultant force?
What is the y component of the resultant force?
What is the magnitude of the resultant force?
What equation should i use?
I was thinking of using the equations that i used to break velocity up into x and y components:
VCOS(ANGLE)
so anyways...
the y component i was thinking:
(8.6^2) + (30) = c^2
Where the root of c^2 would give me the y-component?
I am a little lost any help would be appreciated. Thanks!
I figured it out. :)
  • · Replies 21 ·
  • · Replies 18 ·
