Orientations of curves and diffeomorphism
  • Context: Graduate
  • Thread starter Thread starter WWGD
    Curves Diffeomorphism
This discussion focuses on the relationship between diffeomorphisms and the orientation of Jordan curves in differential geometry. Specifically, it asserts that if a diffeomorphism \( f: M \to N \) is applied to a positively-oriented Jordan curve \( C \) in manifold \( M \), then the image \( f(C) \) retains the positive orientation in manifold \( N \). The conversation highlights the use of tangent spaces and vector space isomorphisms to establish this property, emphasizing the need for a precise definition of a vector field that indicates positive orientation.
  • Understanding of diffeomorphisms in differential geometry
  • Familiarity with Jordan curves and their properties
  • Knowledge of tangent spaces and vector space isomorphisms
  • Concept of vector fields and their role in orientation
  • Study the properties of Jordan curves in differential geometry
  • Learn about the implications of diffeomorphisms on manifold orientation
  • Explore the definition and construction of vector fields in differential geometry
  • Investigate the conditions under which diffeomorphisms are orientation-preserving
Mathematicians, particularly those specializing in differential geometry, topology, and anyone studying the properties of manifolds and curves.
WWGD
Hi:
I am trying to show that if we have a diffeomorphism f:M-->N and C is
a positively-oriented Jordan curve in M ( so that., the winding number of C about any
point in its interior is 1 ) , then f(C) is also positively-oriented in the same sense.
It seems like something obvious to do is to use the fact that if F : M-->N is a diffeo.
then F_* T_pM and T_pF(M) is a V.Space isomorphism. I imagine we can consider the
curve (since it is a Jordan curve, I think reasonably-nice ) as embedded in M , and
then we can see the tangent space of the curve as a subspace of T_pM , and so we
have a vector space isomorphism G* T_qM -->T_F(q)M for q in the curve.
Now, I think we can describe that a curve is positively-oriented by using a V.Field
(which points towards the interior of C at each point, so that if we are walking along the
curve, the interior will be to our left) , and the diffeo. inducing a V.Space isomorphism,
at each point, should preserve this property, but I don't see how to make this more
precise; I don't even know how to define a V.Field that describes positive orientation.
Thanks For Any Ideas.
I realized we cannot talk about Jordan curves without complications (i.e., when
we have a surface of genus >1 ) unless M,N are surfaces. And even then, not
every diffeo. is orientation-preserving.
  • · Replies 30 ·
