New Reply
Huckel's rule for Aromaticity--what is n?
Share Thread Thread Tools
Mar11-09, 02:33 AM   #1
Probably a really stupid question. When using Huckel's rule to figure out if a cyclic compound is aromatic or not, and considering that it must have 4n + 2 pi electrons, how do I figure out what n is?
2. Relevant equations
4n + 2
3. The attempt at a solution
I'll just use Benzene as an example, but I have tried on many other compounds.
I have tried using the number of carbons in the ring (n is one for benzene but there are six carbons, so that doesn't work), the degree of unsaturation (which is 4 for benzene, not one), the number of hetero/electronegative atoms (obviously this doesn't work), and some other less impressive ways of thinking about it. I can't find an explanation anywhere in the textbook and am a bit confused about why they changed n from signifying 'number of carbons' to something else without telling anyone.
Someone told me n is the number of cyclic rings within a compound, which makes sense for benzene (1) and napthalene (2) but if that's the case then I don't know what to do with bigger aromatics such as octo/nano/decatriene--I'm not sure if those in particular are even aromatic due to my lack of understanding of this simple rule, but I did see some examples of bigger rings that had n values of two.
If anyone can shed any light on this at all I would appreciate it. I really can't advance with this material unless I grasp this. Thanks.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Mar11-09, 02:38 AM   #2
oh...does the rule just mean that if the total number of pi electrons are a multiple of four plus two (n is whatever that multiplier is) then it qualifies as aromatic?
Mar11-09, 03:49 AM   #3
Admin
Yes, n is just any integer.
Mar11-09, 03:50 PM   #4
thank you very much
Jan31-10, 09:02 AM   #5
True, n is just any integer, but it has to signify sumthing! i mean, come on, we're talking science, you can't just use any 'n' straightway without challenging its credibility.
Yes, it's true that there are hardly few books which mention what 'n' is. I don't think it's there even in Morrison and Boyd.
To answer the question, it's fundamentally based on the MOT: aromatic systems have 4n+2 electrons, where n is the number of pairs of degenarate bonding orbitals.
Consider Benzene as an example. we concern ourselves only with the pi-orbital system. Benzene has six atomic p-orbitals, which give six pi molecular orbitals (MO's): three bonding orbitals,say [tex]\psi[/tex]1, [tex]\psi[/tex]2, [tex]\psi[/tex]3, and three antibonding, say, [tex]\psi[/tex]4, [tex]\psi[/tex]5, [tex]\psi[/tex]6. the 6 p-electrons arrange themselves in the 3 bonding orbitals. [tex]\psi[/tex]1 has no node, while [tex]\psi[/tex]2 & [tex]\psi[/tex]3 have one node each. Furthermore, The energy level of the orbitals increases with increasing number of nodes. Thus, [tex]\psi[/tex]1 is at a lower energy level than [tex]\psi[/tex]2 and [tex]\psi[/tex]3, which share the same energy level, having one node each. [tex]\psi[/tex]2 and [tex]\psi[/tex]3 are said to be degenerate. Benzene, thus has one pair of degenerate bonding orbitals (i.e, n=1). For higher aromatic systems, the number of pairs of degenerate bonding orbitals increases. Napthlene has 10 atomic p-orbitals, thus, 10 MO's. The 5 bonding orbitals contain 2 pairs of degenerate orbitals and along with [tex]\psi[/tex]1.
[tex]\psi[/tex]1 can contain 2 electrons, while each degenerate pair has a capacity of 4 electrons. Thus, the rule: 4n+2, which is the configuration having all pi-bonding orbitals completely filled, associated with extra stability.
Apr14-11, 11:11 PM   #6
There are some conditions for application of Huckel's rule.One of the most important among them is that the molecule must have a planar structure. It must not contain any sp3 or dsp2 & other hybidised C atom which correspond to a three dimensinal structure. If the molecules do not obey this condition, then even if they have 4n+2 pi electrons, they will not looked upon as an aromatic compound.
the next speculum is that they must have a cyclic structure.
If the concerned molecule satisfies the above said conditions, we may apply the Huckel's rule that is it must contain 4n+2 pi electrons.(n=an integer, ie 0,1,2,3.....) .Each single bond correspond to 0 pi electrons ,each double bond correspond to 2 pi electrons,& each triple bond corresponds to 2*2=4 pi electrons.
If the concerned compound follows all these said conditions, it may be looked upon as an aromatic organic compound.
eg- Benzene(C6H6)
1)All carbon atoms in Benzeze is sp2 hybridised. So it has a planar structure.( 1st condition fulfilled)
2) it has a cyclis ring structure,(2nd condition fulfilled)
3) A benzene molecule contains 3 single & 3 double bond. Hence the total no. of pi electrons= 3*0+3*2=6
putting n=1,
hence 4n+2=6
Hence benzene follows 4n+2 rule.(3rd condition fulfilled)
all the conditions being fulfilled Benzene may be looked upon as an aromatic compound.
New Reply
Tags
organic aromatic
Thread Tools
Similar Threads for: Huckel's rule for Aromaticity--what is n?
Thread Forum Replies
The Golden Rule versus the Platinum Rule General Discussion 63
Chain rule in division rule Calculus & Beyond Homework 6
Chain Rule/Product Rule Question Calculus & Beyond Homework 2
The Chain Rule, death to anyone that breaks the rule! Calculus 55
combining product rule with chain rule Calculus 2
