| Thread Closed |
electrostatics, coulomb force between 2 charges |
Share Thread |
| Mar11-09, 02:55 AM | #1 |
in a mass of 12g of carbon there are NA= 6.02215x1023 atoms, each atom has 6 electrons, 6 protons and 6 neutrons. each electron has a charge of -1.6x10-19C and each proton has a charge of 1.6x10-19C, each neutron has no charge. if all the electrons were at the north pole and all the protons at the south pole, what would be the electric force between them.
(the (correct??) answer is F=73439043N) but i get: in 12g there are 6*NA = 3.61328994x10^24 electrons and 3.61328994x10^24 protons the total electron charge of the 12g is 3.61328994x10^24 * -1.6x10^-19 = (-q)= -578126.39C the total proton charge of the 12g is 3.61328994x10^24 * 1.6x10^-19 = (q)= 578126.39C the distance between them is the diameter of earth, ie 2*radius of earth =2*6400000m=12800000m F=K(q)(-q)/R^2 = K(q/R)^2 =9x10^24*(578126.39/12800000)^2 = 18359808.99N F=18359808.99N which is not the answer in my book, but if i use earths radius instead of diameter, i get F=K(q)(-q)/R^2 = K(q/R)^2 =9x10^24*(578126.39/6400000)^2 = 73439235.97 N which is close enough to the answer, surely the distance between them MUST be the diameter if they are on opposite poles? where have i gone wrong? |
| Mar11-09, 09:50 AM | #2 |
Recognitions:
You are right, you should use the diameter. Sometimes even books make mistakes.
You should really use scientific notation. The way you write is is nearly illegible. Also, if you use 6 decimal places everywhere and then use K=9x10^9 (one decimal place) makes your final answer reliable to only decimal place. |
| Mar11-09, 10:21 AM | #3 |
thanks
| Thread Closed |
Similar discussions for: electrostatics, coulomb force between 2 charges
| Electrostatics Problem: Point Charges and Electric Field | Introductory Physics Homework | 0 | ||
| Electrostatics - line charges | Introductory Physics Homework | 2 | ||
| Electrostatics: A square with point charges on the corners | Introductory Physics Homework | 3 | ||
| Electrostatics - charges on spheres and work done in moving them | Advanced Physics Homework | 8 | ||
| Calculating the Coulomb Force between 2 charges in space | Classical Physics | 6 | ||
