Explaination needed for Stoichiometric problem and is Al salt colorless?
  • Thread starter Thread starter yeahyeah<3
    Salt
The discussion centers on a stoichiometric problem involving the determination of the atomic weight of element Q based on its mass in four different compounds. The correct atomic weight is identified as 19.0 grams, as it is the only option that yields whole numbers when the compound masses are divided by it. Additionally, the colorless solution is confirmed to contain an aluminum (Al) salt, as all other options (Cu, Mn, Ni) are associated with distinct colors. The participants emphasize the importance of understanding the distinction between the mass of element Q and the total mass of the compounds.
  • Basic understanding of stoichiometry
  • Familiarity with atomic weights and periodic table elements
  • Knowledge of inorganic salts and their properties
  • Ability to perform division and interpret results in a chemical context
  • Study stoichiometric calculations and their applications in chemistry
  • Research the properties of common inorganic salts, particularly aluminum salts
  • Learn about the periodic table and atomic weights of elements
  • Explore colorimetric properties of transition metals in solutions
Chemistry students, educators, and anyone interested in mastering stoichiometry and the properties of inorganic compounds.
yeahyeah<3
The mass of element Q found in 1.00 mole of each of four different compounds is 38.0 grams, 57.0 grams, 76.0 grams, and 114 grams, respectively. A possible atomic weight of Q is
a) 12.7
b 19.0
c 27.5
d 38.0
A solution is known to contain an inorganic salt of one of the following
elements. The solution is colorless. The solution contains a salt of:
(A) Cu (B) Mn (C) Fe (D) Ni (E) AL
I do not know the answer to this. I know Cu is blue, Mn is pale pink, Ni is green, Co is redish and Al is silver white.
I know the answer is b. 19.0 grams. However, I'm not 100% sure how to get that answer. I know that it's the only one when the compound masses are divided by it you receive whole numbers. Is that how i was supposed to do the problem? That doesn't make sense to me because other elements could have been in the compound..
THANK YOU :)
Note that it says the mass of element Q in each sample - not the total mass of the sample!
  • · Replies 19 ·
11K
