Faraday's Law of Induction and Current
The discussion focuses on calculating the current in a coil and the rate of thermal energy production using Faraday's Law of Induction. A 22.0-cm-diameter coil with 20 turns of 2.6 mm diameter copper wire experiences a changing magnetic field at a rate of 8.65 x 10-3 T/s. The voltage (V) is calculated as 9.19 x 10-3 V, and the resistance (R) is determined to be 8.96 x 10-2 ohms, resulting in a current (I) of 1.03 x 10-5 A. The power (P) produced, which corresponds to the thermal energy rate, can be calculated using the formula P = I2R.
  • Understanding of Faraday's Law of Induction
  • Knowledge of electrical resistance calculations (R = ρl/A)
  • Familiarity with basic circuit concepts (voltage, current, power)
  • Ability to perform calculations involving geometric properties of circles
  • Study the derivation and applications of Faraday's Law of Induction
  • Learn about thermal energy production in electrical circuits
  • Explore the relationship between current, voltage, and resistance in circuits
  • Investigate the effects of wire diameter and coil turns on electrical properties
Students studying electromagnetism, physics educators, and anyone interested in electrical engineering principles related to coils and magnetic fields.
Kandycat
A 22.0-cm-diameter coil consists of 20 turns of circular copper wire of 2.6 mm in diameter. A uniform magnetic field, perpendicular to the plane of the coil, changes at a rate of 8.65 x 10-3 T/s. Determine (a) the current in the loop, and (b) the rate at which thermal energy is produced.
V = NBA / t
R= pl/A
l = N*2*pi*diameter of coil
A = pi*(radius of wire)2
I = V/R
I understand the part (a)... sort of. Tell me if I did it something wrong.
V = NBA / t
V = (20)(8.65 x 10-3 T/s)(pi*(.0013 m)2) = 9.19 x 10-3 V
R = pl/A
R = (1.72 x 10-8)(20*2*pi*.22 m)/ (pi*(.0013 m)2) = 8.96 x 10-2 ohms
I = V/R
I = 9.19 x 10-3 V / 8.96 x 10-2 ohms = 1.03 x 10-5 A
Part (b) I don't understand. I don't know what I'm finding.
It is power and is found by P=I^2*R.
  • · Replies 21 ·
