Finding equation for trigonometric function based on two points
The discussion focuses on deriving the equation of a cosine function based on two given points. It establishes that a general cosine function is represented as A*cos(Bx+C)+D, which requires multiple points to determine uniquely. However, by restricting the function to the form A*cos(x+B), a unique solution can be found using the two points (x,y) and (w,z). The equations A*cos(x+B) = y and A*cos(w+B) = z allow for the calculation of A and B, respectively, using trigonometric identities.
  • Understanding of trigonometric functions, specifically cosine functions.
  • Familiarity with solving systems of equations.
  • Knowledge of trigonometric identities, including secant and arccosine.
  • Basic algebra skills for manipulating equations.
  • Study the properties of cosine functions and their transformations.
  • Learn how to solve systems of equations involving trigonometric functions.
  • Explore the application of trigonometric identities in solving equations.
  • Investigate the implications of degrees of freedom in function determination.
Mathematicians, physics students, and anyone involved in modeling periodic phenomena using trigonometric functions.
diffusion
Is there any standard way to do this? Specifically, I know the equation I'm looking for is a cosine function, and I know two points. Is there a way to find the equation of the cos function which has been translated and compressed given only these two points?
Unfortunately there's not a unique cosine function given only two points. A general cosine function is something like A*cos(Bx+C)+D, where all of the capital letters are degrees of freedom. You need at least one point for each degree of freedom to have a unique function.
If you want to restrict the function to only compression and translation you could consider a function of the form A*cos(x+B), in which case you could determine a unique one. If the two points are (x,y) and (w,z), then you have to solve the system of equations:
A*cos(x+B) = y ==> A = y*sec (x+B)
and
A*cos(w+B) = z ==> B = arccos(z/A) + w
  • · Replies 139 ·
12K
  • · Replies 17 ·
  • · Replies 36 ·
