Understanding Angular Acceleration: Slowing Down in Clockwise Rotation
The discussion revolves around the concept of angular acceleration, particularly in the context of an object rotating clockwise and slowing down. Participants explore the relationship between angular speed, angular acceleration, and the conventions used to define their directions.
  • One participant questions why angular acceleration is considered positive when an object rotating clockwise is slowing down.
  • Another participant draws an analogy with linear motion, asking about the direction of acceleration when a ball is tossed upwards and slows down.
  • Some participants discuss the implications of defining positive and negative directions in a right-handed coordinate system, noting that counterclockwise is typically positive and clockwise is negative.
  • There is a suggestion that if an object is slowing down while rotating clockwise, its acceleration must be in the opposite direction, which is counterclockwise, thus considered positive.
  • Participants express uncertainty about the definitions and conventions used in their notes regarding angular acceleration and its relationship to the direction of rotation.
  • One participant emphasizes the importance of using the term "acceleration" rather than "decelerating" to avoid confusion, suggesting that acceleration can be positive or negative based on direction.
Participants express varying interpretations of the relationship between angular acceleration and the direction of rotation. While some agree on the conventions of positive and negative directions, others remain uncertain about the implications of these conventions in specific scenarios, leading to multiple competing views.
Participants reference different conventions for defining angular speed and acceleration, which may lead to confusion. The discussion also highlights the need for clarity regarding the terms used, such as "decelerating" versus "slowing down."
This discussion may be useful for students or individuals interested in understanding angular motion, particularly those grappling with the concepts of angular acceleration and the conventions used in physics.
makeAwish
Hello! May i ask a question?
Why angular acceleration is positive if object rotating clockwise is slowing down?
Thanks.
What's the direction of the change in angular speed?
Another example, for linear motion: Toss a ball straight up into the air. It's moving up and slowing down, but what's the direction of its acceleration?
the gravitational acceleration is always coming down.
so the ball's accel is downwards?
hmm. wait. say i define positive upwards, g is negative cos it is downwards.
the ball is deccelerating upwards so it is negative?
Right.
Right.
The ball is moving upwards, but slowing down. So its acceleration is negative (downwards).
(If the acceleration was in the same direction as the velocity--upwards in this case--its speed would be increasing. That's what happens on the way down: both velocity and acceleration point downwards, so it speeds up.)
hmm okay! now i understand. but how abt an object rotating clockwise is slowing down?
when it rotates clockwise, its angular speed is negative right?
i not sure the direction of angular speed as it is not stated in my notes.
my notes just say " angular acceleration is positive if object rotating counterclockwise is speeding up and angular acceleration is positive if object rotating clockwise is slowing down"
If you have a right-handed coordinate system, then counterclockwise directions are positive and clockwise directions are negative.
If something is speeding up, then its acceleration is in the direction of motion. If it's slowing down, its acceleration is opposite the direction of motion.
So which direction is its acceleration? Clockwise or counterclockwise? Then you can decide whether it should be called positive or negative.
The usual convention is that counterclockwise is positive and clockwise is negative.
This is true.
hmm. why " angular acceleration is positive if object rotating counterclockwise is speeding up and angular acceleration is positive if object rotating clockwise is slowing down" is true?
say i use the normal convention, clockwise is negative. why angular accel of obj rotating clockwise slowing down is positive?
Ask yourself:
A) If something rotating counterclockwise speeds up, which way is it accelerating? Clockwise or counterclockwise?
B) If something rotating clockwise slows down, which way is it accelerating? Clockwise or counterclockwise?
Then use the sign convention to determine whether it's positive or negative.
Doc Al said:
Ask yourself:
A) it is accelerating counterclockwise as well so it is positive?
B) it is decelerating in clockwise direction (negative). which means it is accelerating in counterclockwise direction and so it is positive as well?
Sounds good, but with some comments. Careful with the term "decelerating"--I find it more confusing than helpful. (It just means "slowing down".) Much better to stick with acceleration, which can be positive or negative. So for B I would say it's moving clockwise but slowing down (decelerating), thus the acceleration is counterclockwise and thus positive.
i see.. yay! okay. i get it! thanks a lot! thanks thanks :):):)
  • · Replies 16 ·
  • · Replies 20 ·
