Why is the series 1 + -1 + 1 + -1 equal to one half?
  • Context: Undergrad
  • Thread starter Thread starter bowma166
    Behavior Series
The discussion revolves around the series 1 + -1 + 1 + -1 and its assignment of the value one half. Participants explore the nature of convergence, alternative summation methods, and the implications of these methods on the series' value.
  • One participant expresses confusion about the professor's claim that the series sums to one half, noting a lack of explanation.
  • Another participant argues that the series does not converge in the traditional sense, as it yields either 1 or 0 depending on term grouping, and thus cannot be assigned a value without additional context.
  • Some participants mention methods such as Euler's method and Ramanujan summation as potential ways to assign a value to the divergent series.
  • One participant references Abel summation, explaining that while the series diverges, substituting x = -1 in the geometric series formula yields a result of 1/2, which supports the idea of assigning that value.
  • Another participant connects the series to the zeta function, stating that using the eta function leads to the conclusion that the series equals 1/2, contingent on understanding the functional equation related to Ramanujan summation.
Participants generally disagree on the validity of assigning the value one half to the series, with some asserting it cannot be done due to divergence, while others propose alternative summation methods that suggest it can be assigned that value.
The discussion highlights the complexities of series convergence and the various methods of summation that may yield different interpretations of the series' value. There are unresolved assumptions regarding the applicability and acceptance of these summation methods.
bowma166
Today, my professor said something like "The series 1 + -1 + 1 + -1 and so on is defined to be one half... but let's not go into that." and then didn't feel like explaining when people asked him why. I have no idea why that would be true...
It seems like a similar case might be
[tex]\int_{0}^{\infty}\sin x\,\textrm{d}x[/tex]
but that isn't defined to be one half or zero or anything at all.
So why oh why is this true?
[tex]\sum_{n=0}^{\infty}\left(-1\right)^{n}=\frac{1}{2}[/tex]
THis is true...because it is NOT true!
the alternating series
[tex]\sum_{n=0}^{\infty}\left(-1\right)^{n}[/tex]
does not converge at all.
One will get either 1 or 0 as the final sum, depending on how you group the terms. So, by the definition of what we mean with convergence it does not converge.
BUT, i have heard of some sort of Eulers method, or Ramaujan summation, or some different kind of summation, and that might be true, but i have no knowledge whatsoever of those summations.
So, this is not true, if the summation is the common one, i don't know about the others. But people here will enlighten you, just wait until this thread catches the eyes of the right people...
Another reason why one might want the sum to be 1/2 is that
[tex]\sum_{n=0}^{\infty}x^n=\frac{1}{1-x}[/tex]
for [tex]-1<x<1[/tex]. If you put in [tex]x=-1[/tex], then the series on the left diverges, but on the right you get 1/2. This is basically the idea behind "Abel summation", which is a weaker form of Cesaro's method.
I've usually seen Ramanujan summation being used in cases like that.
Equivalently you can write it in terms of the zeta function, by
[tex]\eta(s)=\sum_{n=1}^\infty \frac{(-1)^{n+1}}{n^s} = (1-2^{1-s})\zeta(s)[/tex]
so that,
[tex]\sum_{n=0}^\infty (-1)^{n} = \eta(0) = -\zeta(0) = \frac{1}{2}[/tex]
If you have seen the derivation of the functional equation (which is as far as I have understood is Ramanjuan summation) for the zeta function this sort of "makes sense".
