Force acting on a permanent magnet
The discussion revolves around the forces acting on a permanent magnet when placed in proximity to a current-carrying wire. Participants explore theoretical frameworks, experimental inquiries, and the implications of various models without reaching a consensus.
  • Experimental/applied
  • One participant notes that the force on a wire due to a magnetic field is given by the cross product of current length and magnetic field, questioning the force experienced by the magnet without invoking Newton's 3rd Law.
  • Another participant suggests treating the permanent magnet as a sheet of current to analyze the situation, although they acknowledge that this might not be entirely accurate.
  • Several participants express interest in existing experiments that measure the force on the magnet, with one participant stating they believe no such experiment has been documented.
  • Another participant mentions that electric motors operate on the principle of forces between magnets and current-carrying wires, suggesting this as a relevant example.
  • One participant references historical experiments conducted in the 19th century and suggests looking into Faraday's notebooks for more information.
  • A participant challenges the terminology used to describe the permanent magnet, indicating that "amp turn" may not be a standard term in physics.
  • Another participant proposes a qualitative analysis involving modeling the magnet as a loop carrying current, suggesting that forces would cancel out, leading to no net force on the loop.
  • One participant suggests a practical approach to measuring the force by placing the magnet on a sensitive balance while a conductor is activated nearby.
Participants express various viewpoints on the theoretical modeling of the magnet and the existence of relevant experiments. There is no consensus on the accuracy of the models proposed or the existence of documented experiments measuring the force on the magnet.
Participants mention limitations in terminology and the need for clarity in the models used to describe the forces involved. The discussion reflects uncertainty regarding the appropriate experimental methods and theoretical frameworks.
This discussion may be of interest to those studying electromagnetism, experimental physics, or anyone looking to understand the interactions between magnetic fields and electric currents.
Jedi_Sawyer
http://www.geocities.com/sc_cannon/filxb.bmp
A wire carrying a current I has a magnetic field from a permanent magnet crossing it at right angles. The force on the wire is equal to the cross product of Current Length with the Magnetic Field, B.
What is the force experienced by the magnet? and how do we know it?
Please do not invoke Newton's 3rd Law in the answer.
Without using Newton's 3rd law you would need to use the magnetic field of a current carrying wire and treat the permanent magnet as a sheet of current. The answer, if the problem were to be tractable, would be identical to the one given by Newton's law.
I guess what I am really asking is does anyone know of any experiment that was ever performed that measured the force acting on the magnet and where I can find it. If there is then I don't have to perform it myself.
Incidentally I think that part about treating the permanent magnet as a sheet of current is incorrect as you would have to model it as an amp turn.
Hi, why don't u try googling ur reqd. topic... you might find several interesting links! Gud Luck :smile:
You do realize that a large fraction of the world's electric motors work on this principle, right? I guess anyone rolling up their power window or flipping their power locks would be considered such an experiment.
Yes I've searched, as far as I know this experiment has never been done before and written about. My preferred browser is Yahoo incidentally. No the fact electric motors work does not tell me what I want to know. I'll give it some more time and see if anyone knows about such an experiment.
Experiments of this kind were done in the 19th century, go to your local library and look for a compilation of Faraday's notebooks.
The term 'amp turn' is not standard in physics, perhaps it is an engineering term that I am unfamiliar with. The hits I get on google related to this term are from crackpots building perpetual motors. In any case, of course it is appropriate to describe a permanent magnet in terms of currents, since all magnetic phenomena arise from and have to do with moving charges cf. Maxwell's equations.
Why not? You want the force exerted on a permanent magnet by a current carrying wire, right? That's a motor.
First we use Faraday's induction equation:
where V = voltage and dA = area, n =unit vector perpindular to dA
V = - d/dt integral (B(t) dot n dA) over A
["dot" means dot product]
Magnitude of B is defined by the above equation, using defined values of volts, area, and time.
1 tesla defined as 1 volt-second per square meter as per above induction equation.
Then we calculate the force given by the Lorentz equation F = I x B
Thanks Bob, yur reply was actually too technical as I couldn't figure out what it had to do with my problem. My own qualatative analysis is that if you modeled the magnet as a loop carrying a current and crossed it with a wire carrying a current at any arc you want, since the contour Integral of the forces acting on the wire are holomorphic, yields a net force on the wire, but there is no net force on the loop as all forces cancel.
I guess the easiest thing to do now is just design and run the experiment and write about it.
Hasta
The easiest way is to put your magnet on a sensitive balance with the conductor suitably supported close to it.Switch on and voila. :rolleyes:
