Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Science Education > Homework & Coursework Questions > Introductory Physics
Reply
image How to find initial velocity from range and angle. Share It Thread Tools Search this Thread image
Old Mar14-09, 11:04 PM                  #1
iHEARTmath
iHEARTmath is Offline:
A golf ball is hit at an angle of 30 degrees, it travels 50m landing straight in the hole. Ignoring air friction, what is the initial velocity?
2. Relevant equations
not too sure, d=vi.t+1/2.a.ts∧2, vf=u∧2+2.a.d, v=u+a.t, d=u.t
3. The attempt at a solution
Vertical initial Velocity= usin30
Horizontal initial velocity= ucos30
Old Mar14-09, 11:21 PM                  #2
LowlyPion
LowlyPion is Offline:
Recognitions:
Homework Helper Homework Helper
Re: How to find initial velocity from range and angle.
Welcome to PF.
That's a good start. Maybe try to eliminate time from your equations?
Old Mar15-09, 12:07 AM                  #3
iHEARTmath
Could you give some advice in how I would do that? Like which formula to use?
Can it be figured out using these formulas?
Old Mar15-09, 12:18 AM                  #4
iHEARTmath
t= d/u, so t=d/ucos30. Do I leave it as that or.. t= 50/ucos30?
Old Mar15-09, 01:54 AM                  #5
The Liberator
The Liberator is Offline:
remember that when there is no air resistance the vertical and horizontal components of the velocity are completely separate from each other, and because there is no air resistance, the horizontal velocity stays the same throughout the flight.
P.S. Have I said too much?*
*this is to the admins and mentors and other senior members
Old Mar15-09, 03:08 AM                  #6
iHEARTmath
I tried working it out...
Uv= usin30
Uh= ucos30
t= d/Uh, t= 50/ucos30 s=Uv.t+(1/2).-9.8∧2
and does s=0? I can't remember why.
0=usin30.(50/ucos30)+(1/2).-9.8.(50/ucos30)∧2
0=??? how do i simplify this?
Old Mar15-09, 03:30 AM                  #7
The Liberator
maybe try and refer to earlier notes on this, that the book might have talked about, to do with components of vertical/horizontal linear motion…
Old Mar15-09, 03:37 AM                  #8
iHEARTmath
if s=0 it's simplified to u= (square root of 9.8x50)/cos30 and the answer is 23.78661943
but if s=50 the answer is 27.80110847
What is correct? and why?
Please help
Old Mar15-09, 04:02 AM                  #9
The Liberator
okay then.
When s=25, then v will be at it's minimum value, and there will be no vertical velocity at all. you can then work out what the vertical distance of s is (with the help of tan 30). from that answer, you can then use t = sv…
…then everything else will slowly fall into place.
Old Mar15-09, 04:29 AM                  #10
iHEARTmath
Ah.. what do I use the vertical height for? 25tan30= 14.43375673
so then,
Uv=0
Height?=14.43375673
Old Mar15-09, 04:35 AM                  #11
Phrak
Phrak is Offline:
Recognitions:
PF Contributor PF Contributor
Good grief, golf balls are not pojectiles. Fire your professor.
Old Mar15-09, 04:46 AM                  #12
iHEARTmath
Vf=Vi+-9.8x(25/Vi.cos30)
0=v-9.8x(25/v.cos30)
v=9.8x(25/v.cos30)
u∧2cos30=9.8x25
u∧2=(9.8x25)/cos30
u= square root((9.8x25)/cos30)
u=16.8196799??
Old Mar15-09, 04:53 AM                  #13
The Liberator
the vertical height can be used to find the flight time for the golf ball half way through the overall flight.
With that you can then find the initial velocity of the ball.
Old Mar15-09, 05:04 AM                  #14
iHEARTmath
What is the formula that is needed to find the flight time for half of the journey?
Old Mar15-09, 05:32 AM                  #15
The Liberator
If you have the vertical displacement, then it would be this: t=sv
As s = 25 m, and at the halfway point of the flight time, the golf ball is at it's highest point, the vertical velocity is 0 ms-1, then you can do the maths.
Also, as a reference, here are the formulae.
Old Mar15-09, 05:35 AM                  #16
iHEARTmath
Sorry I don't understand, t=sv; t=25x0? t=0?
image image
Reply
Tags
angle, range, velocity
Thread Tools
Similar Threads for: How to find initial velocity from range and angle.
Thread Thread Starter Forum Replies Last Post
finding initial velocity and theta, given range and height Seri Introductory Physics 1 Sep14-08 12:35 PM
Angle of initial velocity Lmaonade Introductory Physics 2 Oct25-07 08:30 PM
given angle and distance traveled find initial velocity shaunk Introductory Physics 3 Oct19-07 01:22 AM
Given range and angle - but not time - find initial velocity? exi Introductory Physics 4 Jun13-07 07:57 PM
angle, horizontal range, velocity marinabradaric Introductory Physics 1 Apr19-07 12:18 AM
Powered by vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
