Pressure to Achieve 10 m/s Flow Into Underwater Reservoir
  • Thread starter Thread starter ACE_99
    Pressure
The discussion centers on calculating the pressure required to achieve a flow rate of 10 m/s for liquid ammonia into an underwater reservoir located 100 m below the surface. The relevant equations include Bernoulli's equation and the Darcy-Weisbach equation, which accounts for irreversible pressure drops in pipes. The density of liquid ammonia is specified as 682 kg/m³, and the pipe diameter is 5 cm. Understanding both equations is crucial for accurately determining the necessary pressure.
  • Bernoulli's equation for fluid dynamics
  • Darcy-Weisbach equation for pressure drop in pipes
  • Fluid properties, specifically density of liquid ammonia
  • Basic principles of hydrostatics
  • Study the application of Bernoulli's equation in fluid flow scenarios
  • Learn how to apply the Darcy-Weisbach equation for calculating pressure drops
  • Explore the properties of liquid ammonia and its implications in fluid dynamics
  • Investigate hydrostatic pressure calculations for underwater applications
Engineers, fluid mechanics students, and professionals involved in hydraulic systems or underwater fluid transfer will benefit from this discussion.
ACE_99
What pressure Pr, is required to achieve a flow rate of 10 m/s into the underwater reservoir if the tank is 100 m below the surface. Liquid ammonia is to be transferred with a density of 682 kg/m^3 and the pipe diameter is 5 cm. The reservoir underwater is at local hydrostatic pressure. A picture is included.
Bernoulli's Eqn: P1 + (1/2)[tex]\rho[/tex]U2 +[tex]\rho[/tex]gz
At first I thought that it was as simple as plugging in the values given into the formula and solving for P1, but then I realized that they gave us the diameter of the pipe too so I'm guessing it has some significance. I can't seem to figure it out though, any help would be great.
http://i429.photobucket.com/albums/qq12/ACE_99_photo/Untitled-2.jpg"
Hi Ace. Bernoulli's equation is just one of the necessary equations to calculate this. The other is the irreversible pressure drop of fluid that flows through a pipe which is best done using the Darcy Weisbach equation. You can plug the DW equation into the B equation simply by recognizing that there is a permenant pressure drop under flow equal to the pressure predicted by the DW equation.
Take a look at the DW equation and try to understand how the flow of fluid corresponds to some pressure drop in a pipe.
  • · Replies 24 ·
  • · Replies 16 ·
