How to Solve RL-Circuit and Transformer Power Problems?
  • Thread starter Thread starter Hannisch
The discussion revolves around two problems related to electrical circuits, specifically focusing on an RL circuit involving a motor and a transformer power transmission scenario. Participants are exploring concepts of resistance, back emf, and power loss in transmission lines.
  • Mixed
  • Participants are attempting to apply Ohm's law and are questioning the implications of different current values at startup and normal operating conditions. There is also a request for conceptual guidance regarding the power transmission problem and the use of transformers.
Some participants have offered alternative approaches, suggesting the use of an RC model for the motor problem and discussing the importance of writing out dynamic equations. Others are still seeking clarity on how to approach the problems and are exploring different angles of reasoning.
Participants note that the problems are not from their textbook, indicating a potential gap in their understanding of the material. There is also mention of confusion regarding the specifics of the transformer problem and the resistance of the transmission lines.
Hannisch
Okay, I've got two problems that are giving me issues and it's quite annoying. We're all kinda stuck on them and we couldn't get our teacher to explain them to us (yarghhh).
A motor is designed to operate on 117 V and draws a current of 12.2 A when it firsts starts up. At its normal operating speed, the motor draws a current of 2.30 A. Obtain (a) the resistance of the armature coil, (b) the back emf developed att normal speed and (c) the current drawn by the motor at one-third normal speed.
[tex]I(t) = \frac{E}{R}(1-e^{-{\frac{R}{L}t}})[/tex]
[tex]E= - N \frac{d \Phi }{dt} = -L \frac{dI}{dt}[/tex]
Where E = emf.
So, what we at first thought for (a) was that normal speed is some sort of .. evening out or something similar to that, so we wanted to use Ohm's law to find the resistance (now looking at the numbers that's sort of absurd - how can Imax be lower than the initial one? Doesn't really make sense), but obviously that's wrong, we realized when we came to (b). And we're stuck. We don't know how to proceed and for me it's a bit what's what? Is 12.2 the Imax? Like, what does the question actually say?
A generating station is producing 1.2 * 106 W of power that is to be sent to a small town located 7 km away. Each of the two wires that compromise the transmission line has a resistance per kilometre of length of 5.0 * 10-2 Ohm/km. (a) Find the power used to heat the wires if the power is to be transmitted at 1200 V. (b) A 100: l [okay, so I'm not too sure about this last thing - it looks like it says this, but I can't be 100% sure, bad copy..] step-up transformer is used to raise the voltage before the power is transmitted. How much power is now used to heat the wires?
I need conceptual help here, first of all - this question is not from our textbook, but another one which my teacher has and our book apparently doesn't go through this enough, cos I'm so lost. I don't even really know which angle to approach the problem from. Hint in the right direction, anyone?
Your working too hard at it. Replace the motor with a series RC and take startup as Vc=0,
Then compute the resistance. having the resistance, and subsequent applied voltage and current you can calculate Vc. Subsequently 1/3 speed will produce Vc/3 etc...
The RC network is just an intellectual prop and can dropped in favour of straightforward calculations.
Ray
Ah, thanks so much! I wasn't even close to thinking RC - we haven't done them in a while and I apparently just thought that since we're currently doing magnetic flux and inductance it would have something to do with that.
Well in my experience the RC model is most intuitve to start; and then add the L when dealing with switching transients.
This is experience, but really should write out the dynamic differential equation for the current loop and then make identifications of terms with RLC for a intuitive representation. Writing the loop equations correctly in the time domain will allow you to deal with more complicated problems. For instance the windings have interwinding capacitance that bypasses the L and you could also loads that have complex dynamics that need to be incorporated. Hopefully these are all refinements of a simple start, but sometimes are not. KISS but only simple enough to capture the problems.
Of course the more correct way is to directly transform the "real" dynamic equations into the LaPlace domain and manipulate; but if you only deal with motors once every decade then the RLC model is handy.
Ray
9K
