Energy in an Electric Field of an EM Wave
The discussion revolves around the relationship between energy in an electric field and the wavelength or frequency of electromagnetic waves. Participants are exploring how intensity relates to energy density and the electric field strength within the context of classical electromagnetics and quantum mechanics.
  • Participants are attempting to derive an equation that connects electric field strength to wavelength and intensity. Questions arise about the appropriateness of certain equations and the relationship between electric and magnetic fields. Some participants reference classical and quantum perspectives on energy in electromagnetic waves.
There is an ongoing exploration of various equations and concepts related to electric field strength and energy density. Some participants have provided links to resources, while others are questioning assumptions and clarifying definitions. Multiple interpretations of the relationships involved are being discussed.
Participants are navigating constraints such as the definitions of energy in electric and magnetic fields, and the appropriateness of certain equations in the context of photons and electric fields. There is a mention of homework rules that may limit the type of assistance sought.
bobsalive
I have been desperately trying to find an equation (or a set of equations where I can derive an equation) that shows a relationship between the energy in an electric field and the wavelength or frequency of an electromagnetic wave.
I am trying to show a relationship between Wavelength and Intensity of an electromagnetic wave, and working backwards, the Intensity is proportional to the Energy Density of the wave, half of which is the electric energy density, which can be calculated by multiply the permittivity of free space with the energy in the electric field squared. But I can't find the equation for energy in the electric field (in relation to wavelength)! Any ideas?
E = hf
That is the energy in the wave, not the energy in the electric field! There is energy in the magnetic field as well isn't there?
have a look at this
http://www.phy.duke.edu/~lee/P54/energy.pdf
In classical electromagnetics I think the energy is related directly to the Intensity (or field strength squared) independent of wavelength, this is because the average of a sinusoid is independent of its period.
However in the quantum limit the energy of a photon is directly related to the wavelength by [tex]E = \hbar f[/tex] as mentioned previously
Thanks lanedance for the link. I read it, and I've already covered the stuff in that page, what I am trying to find is an equation that will tell me what E equals (E as in the electric field strength, NOT the energy of the wave).
A photon does not have a charge, so E = f/q is an inappropriate equation...
Edit: I know that I = uc, and because u = εE^2, I = cεE^2. But what does the E equal?
I'm not totally sure what you're asking...:rolleyes:
The field E(x,t) is an allowable solution of the wave equation generated from maxwells equations
One allowable example of a plane wave propagating in the x dir'n with frequency [tex]\omega[/tex] would be
[tex]E(x,t) = (0,E_y,0)[/tex]with [tex]E_y (x,t) = E_0 \cos{(kx -\omega t)}[/tex]
[tex]B(x,t) = (0,0,B_z)[/tex]with [tex]B_z (x,t) = B_0 \cos{(kx -\omega t)}[/tex]
with magnetic & electric field strengths related by:
[tex]B_0 = \frac{E_0}{c}[/tex]
the E is in fact the electric field.. so if we palced a test charge q in the electric field it would experience a force F = Eq
is this what you mean?
I'm not sure about maxwell's equations, but I think I've sorted out the problem by using E=V/d (Electric Field = Voltage / Distance) which has provided me a suitable answer.
Thanks for all your help!
This might help too ... (from
http://www.osha.gov/SLTC/radiofrequ...etic_fieldmemo/electromagnetic.html#section_3 )
Pd = E x H
Watts/meter2 = Volts/meter x Amperes/meter
where
Pd = the power density,
E = the electric field strength in volts per meter,
H = the magnetic field strength in amperes per meter.
The above equation yields units of W/m2. The units of mW/cm2 are more often used when making surveys. One mW/cm2 is the same power density as 10 W/m2 The following equation can be used to obtain these units directly:
Pd = 0.1 x E x H mW/cm2
  • · Replies 17 ·
  • · Replies 21 ·
  • · Replies 30 ·
