Kinetic energy and Angular momentum
The problem involves calculating the kinetic energy and angular momentum of a system consisting of five identical particles mounted on a rod, with the system rotating about an axis perpendicular to the rod through one of the end masses. The subject area includes concepts of rotational dynamics, specifically moments of inertia and energy in rotational motion.
  • Participants discuss the calculation of the moment of inertia for the rod and the particles, considering their distances from the axis of rotation. There are attempts to derive the total moment of inertia by summing contributions from both the rod and the particles. Some participants question the setup and the interpretation of the distances involved.
The discussion has seen various attempts to clarify the calculations for the moment of inertia and kinetic energy. Some participants have provided insights into the necessary equations, while others have expressed confusion about specific terms and the overall approach. There is an ongoing exploration of the correct interpretation of the problem setup and the calculations involved.
Participants are working under the constraints of a homework assignment, which may limit the information available for discussion. There are indications of potential misunderstandings regarding the application of formulas and the conversion of units, particularly in relation to angular velocity.
Stryder_SW
Five identical particles of mass m = 0.30 kg are mounted at equal intervals on a thin rod of L = 0.87 m and mass M = 2.0 kg, with one mass at each end of the rod. If the system is rotated with angular velocity ω = 50 rev/min about an axis perpendicular to the rod through one of the end masses, determine the following.
(a) the kinetic energy of the system
(b) the angular momentum of the system
2. The attempt at a solution
SOLVED
(a) K=.5(Itotal)w^2
K=.5(1/3L2*M + 30/16L2*m)w2
K=12.75312242kg·(m/s)2
(b)Angular Momentum=Itotal*w
Angular Momentum=4.87133934kg·m2/s
They want you to develop the I for this configuration.
If there are 5 evenly spaced, then you have to determine the distances (L/4 is the separation) and then develop the sum of the moments of inertia of the parts. The rod and the weights. However this is a little trickier. The weight in the middle needs to be properly accounted for.
So you can use the I of a rod rotated about it's end and then the 4 weights evenly spaced at L/4 along its length.
Well what you're describing pretty much sounds like what I did, Find the I of the rod which is just (1/3)Md^2 where d = .87m. Then find the Inertia of each particle with a varying L which would come out as L1=0, L2=.2175, L3=.435,L4=.6525,L5=.87. so the general form for the Inertia of the particles is .5m*(Ln)^2 (n being 1-5). then just add all Irod and Iparts. multiply by (w^2)/2.
Stryder_SW said:
Well what you're describing pretty much sounds like what I did, Find the I of the rod which is just (1/3)Md^2 where d = .87m. Then find the Inertia of each particle with a varying L which would come out as L1=0, L2=.2175, L3=.435,L4=.6525,L5=.87. so the general form for the Inertia of the particles is .5m*(Ln)^2 (n being 1-5). then just add all Irod and Iparts. multiply by w^2.
From the end I get (1/3L2*M + 30/16L2*m) for I
what do you mean by "from the end"
about an axis perpendicular to the rod through one of the end masses...
From the problem right? Don't you need I relative to one end?
yeah, relative to the end its rotating about. but is that I equation you gave supposed to be the total I? more specifically is the (30/16L2*m) part the I for all the particles summed together? and if it was all the particles added together what would L be?
m is the mass of the little weights.
(L/4)2 + (L/2)2 + (3L/4)2 + L2 = 30/16 L2
1/16 + 4/16 + 9/16 + 16/16 = 30/16 right?
ah, I see. That makes so much more sense now XD. so Itotal=(1/3L2*M + 30/16L2*m), so to get K it would be (1/2)(Itotal)w2 and in this case w=50rev/min
so Itotal=(1/3(.87m)2*2kg + 30/16(.87m)2*.3kg)=.93035625kg*m2
K=(1/2)(.93035625kg*m2)(5.235987756/s))2=12.75312242 kg*(m2/s2)
OK got it, thank you SO MUCH Pion.
K=(1/2)(.93035625kg*m2)(50/60(rev/s))2=.323043646 kg*(m2/s2)
Obviously I'm still doing something wrong, cause that's not a right answer.
There you go. You want radians/sec.
K=(1/2)(.93035625kg*m2)(5.235987756/s))2=.323043646 kg*(m2/s2)
Much better.
Good luck.
  • · Replies 17 ·
18K
