How Do Laser Beam Properties Change When Passing Through Glass?
The discussion focuses on the behavior of a laser beam with a power of 100 MW and a diameter of 1 mm as it passes through a glass window with a refractive index of 1.59. The peak electric field in the air is calculated to be 3.79 x 10^12 V/m. Additionally, the pressure exerted by the laser beam on a conducting surface is determined to be 1.27 x 10^14 W/m². These calculations are based on the equation P = ε_0 E_o², which relates power to the electric field strength.
  • Understanding of electromagnetic wave properties
  • Familiarity with the concept of refractive index
  • Knowledge of the equation P = ε_0 E_o²
  • Basic principles of optics and laser physics
  • Research the effects of different refractive indices on laser beam propagation
  • Learn about the relationship between power, electric field, and magnetic field in electromagnetic waves
  • Explore the calculations for laser beam intensity and pressure on surfaces
  • Investigate the implications of laser beam properties in various materials
Students in physics, optical engineers, and professionals working with laser technologies will benefit from this discussion, particularly those interested in the interaction of laser beams with different materials.
hhhmortal
A laser beam, having a power of 100 MW and a diameter of 1mm, passes through a glass window of refractive index 1.59. Find the peak values of the electric field and magnetic fields of the laser beam (a) in the air and (b) in the glass.
P = ε_0 E_o^2
I found the pressure that the wave exerts on the conducting surface, to be 1.27 x 10^14 W/m^2
and then I found the magnitude of the electric field to be 3.79 x 10^12 V/m
^Bump
Thanks
11K
  • · Replies 23 ·
16K
12K
