Torque and Force due to an external magnetic field
The discussion centers on the relationship between torque and force in the context of an external magnetic field, specifically described by the equation Torque N = μ ∧ B, where μ represents the dipole moment and B is the magnetic field. It is established that torque can be expressed in this form even if B is a function of position, such as B = B * x. The force on a magnetic dipole is zero when B is constant due to equal and opposite forces acting on the dipole's ends, while torque remains non-zero unless the dipole is aligned with B. The discussion references the Stern-Gerlach experiment as a historical example of magnetic dipole behavior in non-constant fields.
  • Understanding of magnetic dipole moments
  • Familiarity with vector calculus and cross products
  • Knowledge of classical electromagnetism principles
  • Awareness of the Stern-Gerlach experiment and its significance
  • Study the mathematical formulation of torque in varying magnetic fields
  • Explore the implications of magnetic dipole interactions in non-uniform fields
  • Investigate the principles behind the Stern-Gerlach experiment and its applications
  • Learn about the behavior of magnetic materials in external magnetic fields
Physicists, electrical engineers, and students studying electromagnetism, particularly those interested in the dynamics of magnetic dipoles and their applications in experimental physics.
wam_mi
Torque N = μ ∧ B
where μ is the dipole moment of the loop,
and B is an external magnetic field.
Q1 Is it true that we can only write the Torque due to an external magnetic field in this form if and only iff B is a constant? What happens, say, if B = B * x (in the z-direction) where x is a variable, is it still possible to write Torque in this form, where μ is a constant.
Q2 Why is it that Force = 0 but Torque is not = 0 when the external magnetic field is constant?
Cheers guys
1. The torque is given by the cross product [tex]\mu\times B[/tex] even if B is a function of position.
2. The force on a magnetic dipole is given by
[tex]{\vec F}=\nabla(\mu\cdot}{\vec B}[/tex],so it vanishes if B is constant.
As a simple model, think of a bar magnet. The force on the N and S ends will be equal and opposite in a constant magnetic field.
The torque on a magnetic dipole, like a compass needle, is non-zero whenever it is in a constant magnetic field B (and if the dipole is not aligned with B). There is no net translational force on the needle, however.
If B is non constant, specifically B = B * x, where B is along z, there can also be a net translational force on a magnetic dipole. A good example is the magnetic force on a beam of neutral silver atoms, which are now known to have a magnetic moment. Because the atoms did have a magnetic dipole moment, the beam was deflected (transverse force) in a magnetic field. This was the basis of the Stern Gerlach experiments in 1921-23, which later won the Nobel Prize in physics.
  • · Replies 22 ·
  • · Replies 16 ·
