How Does Kinetic Energy Affect Force in a 1D Atomic System?
The discussion focuses on the relationship between kinetic energy and force in a one-dimensional atomic system influenced by a magnetic field and an external electrostatic force. The kinetic energy is defined as K = 0.5*m*v², while the potential energy U(x) is modeled based on the position of the atom relative to a defined range. The force F(x) acting on the atom is derived from the potential energy, confirming that it is conservative. The discussion also explores the conditions under which the atom can escape the potential well, requiring the external force F0 to exceed the potential energy U0.
  • Understanding of classical mechanics, specifically kinetic energy and potential energy concepts.
  • Familiarity with conservative forces and their properties.
  • Knowledge of magnetic fields and their effects on charged particles.
  • Basic principles of electrostatics, particularly the concept of constant forces.
  • Study the derivation of forces from potential energy functions in classical mechanics.
  • Learn about the implications of conservative forces in physics.
  • Explore the effects of magnetic fields on charged particles in one-dimensional systems.
  • Investigate the conditions for escape velocity in potential wells, including the role of external forces.
Students and professionals in physics, particularly those studying classical mechanics, atomic systems, and the interactions of charged particles with fields.
MaxManus
We addrewss a one dimensional system. An atom moves along the x-axis with a kinetic energy K = 0.5*m*v**2. In the range -x0<x<x0 the atom enters the trap, and is affected by a magnetic fiels. The interaction with the magnetic field gives rise to a potential U(x) which we model:
for abs(x)>= x0, U(x) = U0
for abs (x) < x0, U(x) = U0*abs(x)/x0
a) Find the force F(x) on the atom from the magnetic field. Is this force conservative?
Let us also assume that the atom is charged and also subject to a constant electronic force, F0 acting in the positive x-direction
b) If the atom has kinetic energy K = 0 at x = 0, how laarge must F0 be in order for the atom to escape? And if the kinetic energy is K = U0/2 at x = 0, how large must F0 then be in order for the atom to escape.
a)
F = -dU/dx
F = 0 for abs(x) >= x0
F = U0/x0 for -x0<x<0
F = -U0/x0 0for 0<x<x0
The force is conservative for it is only dependent on the position
b) Here I need some help.
Is the idea that the force must give the atom larger total energy than u0?
Not sure if that would be the case or not.
The way I think about it is, how is the potential modified due to the presence of the constant electrostatic force?
