Maximum compression in a spring
The problem involves two carts of equal mass colliding elastically on a frictionless track, with a spring attached. The original poster seeks to determine the velocities of the carts after the collision and the maximum compression of the spring.
  • Participants discuss the nature of elastic collisions and the energy transfer involved, with some suggesting that the collision behaves like an inelastic collision due to spring compression. Questions arise regarding the calculation of maximum spring compression and the conservation of energy principles.
Some participants have provided insights into the relationship between kinetic energy and spring potential energy, suggesting methods to approach the maximum compression calculation. However, there is no explicit consensus on the correct interpretation or method to find the maximum compression.
Participants note the initial conditions of the carts and the assumptions regarding energy conservation during the collision. There is mention of the need to consider the system's total energy before and after the collision, as well as the velocities of the carts at maximum compression.
Knfoster
Two carts of equal mass, m = 0.300 kg, are placed on a frictionless track that has a light spring of force constant k = 48.9 N/m attached to one end of it. The red cart is given an initial velocity of v0 = 3.13 m/s to the right, and the blue cart is initially at rest. If the carts collide elastically, find the magnitude of the velocity of the red cart just after the first collision. Find the magnitude of the velocity of the blue cart just after the first collision.
Find the maximum compression in the spring.
pe=1/2*k*change in x
m1v1=m2v2
THe velocity of the red cart after the first collision=0 m/s
the velocity of the blue cart after the first collison=3.13 m/s
I don't know how to find the maximum compression in the spring... Please help. Thanks.
Okay, I have done some work with this before, but if I'm wrong, I hope someone else can correct me. When two objects collide elastically, they naturally compress and kind of stick together momentarily. In this case, the collision acts like an inelastic collision, which causes some of the energy of the system to be stored in the spring. So, if you treat that system during the collision as inelastic you get the velocity of the two carts (together) to be 1.57 m/s and the KE to be 0.735 J. The total energy of the system is 1.47 J. Using these values with the conservation of energy, you should be able to calculate the maximum compression in the spring.
The maximum compression of the spring should occur at the point when the two bodies come to a common velocity. At this point, one body will have lost velocity and the other will have gained, and they will be at their point of closest approach to each other, ie, the maximum compression of the spring. Thereafter, the spring begins to expand and the velocities begin to separate.
If I'm interpreting the problem correctly, I believe you just have to find the compression of the spring when all of the kinetic energy of the blue cart is put into the compression of the spring.
As you said.. after the collision:
The velocity of the red cart is 0 m/s
The velocity of the blue cart is 3.13 m/s
Thus you know the total energy of the system before the blue cart hits the spring. This is equal to the energy
of the system after it hits the spring.
[tex]\frac{1}{2}mv^{2}=\frac{1}{2}kx_{max}^{2}[/tex]
(the velocity of the blue cart is 0 at the max compression... that is why there is no [tex]\frac{1}{2}mv^{2}[/tex] term on the RHS)
Hope it helps!
  • · Replies 16 ·
  • · Replies 40 ·
