Integration of a Sine function and a fraction
The discussion revolves around the integration of the function 2 + 5sin((4*pi*x)/(25)), which is part of a longer word problem. Participants are exploring methods for integrating this expression, particularly focusing on the sine component.
  • Mixed
  • Participants discuss the use of u-substitution as a method for integration, with suggestions to clarify the substitution process. There are attempts to apply the chain rule and reverse chain rule, but some participants question the correctness of these approaches.
Some guidance has been offered regarding the use of substitution and the correct handling of the integral. Participants are actively engaging with each other's reasoning, exploring different interpretations of the integration process without reaching a consensus.
There are indications of confusion regarding the integration steps and the application of substitution, with participants expressing uncertainty about the correct form of the integral after substitution.
longhorn2010
It is a really long word problem, but I only need help with integrating one part of the proble.
I need to know how to integrate 2+5sin((4*pi*x)/(25))
I tried using the chain rule by first integrating the sin into negative cosine, and then integrating the inside, giving me: 2x-cos((4*pi*x)/(25))*(2*pi*x^2)/(25)
Sorry, I don't know how to do all the symbols, or any of them really.
No, not quite. Do a u substitution. u=4*pi*x/25, du=4*pi*dx/25.
Here's your integral in latex tags, and split into two integrals.
[tex] \int 2dx + 5sin(\frac{4 \pi x}{25})dx[/tex]
The first integral gives you 2x + a constant.
Your explanation of using the reverse chain rule and your work are incorrect. You don't integrate the sine part, and then integrate what's inside. This isn't how it works. If it were, you could differentiate your answer and get back to the integrand you started with.
Use an ordinary substitution u = [itex]4/25 \pi x[/itex], so du = [itex]4/25 \pi dx[/itex]. Once you get this in place, your integral will be [itex]\int 5sin(u)du[/itex], which is pretty straightforward to do.
Thanks for the explanation. I just want to confirm though, that the integral should be
-5cos(du), right?
The integral is -5*cos(u). Not du. But don't forget the factors that are coming from changing dx to du. Why don't you just do it and we'll check your answer?
So would the answer then be -5cos((2*pi*x^2)/(25))?
No again. Can you show us how you worked that out using the substitution u=4*pi*x/25?
I tried to integrate the part after the cosine. I took out the "x" and got (x^2)/(2) and then multiplied it back into the (4*pi)/(25), and simplified it to (2*pi*x^2)/(25).
Do I instead not bother with the inside of the cosine, and just leave it as is, as in (4*pi*x)/(25)?
You just substitute. You have integral 5sin(4*pi*x/25)*dx. u=4*pi*x/25. du=(4*pi)dx/25. That gives you 5*sin(u)*dx. Now you just replace dx=25*du/(4*pi). Then you have an integral all in u. Integrate it. Now reverse the substitution to get an expression in x. Have you really never done this before?
  • · Replies 19 ·
