Concave mirror - finding object and image distance
The problem involves a concave mirror with a focal length of 27.2 cm and a specified distance of 50.2 cm between an object and its image. Participants are tasked with finding the object and image distances, given that the object is located beyond the center of curvature.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the relationships between object distance, image distance, and focal length using the mirror equation. There are attempts to set up equations based on the distance between the object and image, but confusion arises regarding the correct substitutions and signs in the equations.
Some participants express uncertainty about their approaches and whether they are on the right track. There is a recognition that certain calculations do not satisfy the mirror equation, prompting further questioning of assumptions and setups.
Participants are working under the assumption that the object lies beyond the center of curvature, and there is a noted discrepancy in the signs of the distances calculated, which raises questions about the validity of their results.
phys62
A concave mirror has a focal length of 27.2 cm. The distance between an object and its image is 50.2 cm. Find (a) the object and (b) the image distance assuming that the object lies beyond the center of curvature.
f=1/2 R
1/object distance + 1/image distance = 1/f
image distance - object distance = 50.2 cm
(image distance + object distance)/(image distance*object distance) = 1/f
50.2/(image distance*object distance)=1/27.2
image distance*object distance=1365.44
image distance=50.2 + object distance
substitute in and get: (50.2 + object distance)object distance = 1365.44
quadratic equation solves for object distance = 69.77 or 19.57 cm
Am I even doing this right?? If so, I'm stuck from here.. Thanks for any help you can give!
f=1/2 R
Whoops.
But you substituted 50.2 cm for image distance + object distance
Try substituting for "image distance" in
1/object distance + 1/image distance = 1/f​
Can anyone help me figure out if I'm even on the right track?
so I tried saying image distance = 50.2 + object distance
substituting that into 1/object distance + 1/image distance = 1/f
I got object distance = -620.65 cm
then image distance would = -620.65 + 50.2 = -570.45 cm
This is incorrect... Have I done this right, and the 620.65 simply needs to be positive? Or am I completely off track?
Something is wrong there. Those numbers definitely don't satisfy the equation,
1/(-620.65) + 1/(-570.45) = -0.00336
While 1/f = 1/27.2 = +0.0367
Since f (and also 1/f) is positive, the object and image distances cannot both be negative.
