Thread Closed
Wave question - stretched string
Share Thread Thread Tools
Mar24-09, 03:39 PM   #1
A stretched string has length L and is attaached to a rigid support at either end. The string displacement from equilibrium at t=0 is given by:
y(x,0) = sin(3(pi)x/L)
and the velocity of the string is:
y'(x,0) = (3pi/L)sqrt(T/rho)sin(3(pi)x/L)
where T = tension in the string, and rho = its mass per unit length
and sqrt(T/rho) is the wave velocity of transverse waves on the string.
Give the form of the displacement y for all x, t.
2. Relevant equations
(This is kind of where I'm stuck). I assumed the general equation of a wave was y = sin(kx)cos(wt), but that didn't work.
I then tried with y = sin(kx-wt), but that also didn't seem to work.
3. The attempt at a solution
I tried to use the general equation for a wave, differentiate it wrt t, plug in t=0 and compare it to the given velocity equation, but whenever I try I end up with a cos term instead of sine. I really can't figure out how it's a sine term in both the displacement and velocity.
If I used y = sin(kx)sin(wt), then at t=0, y=0.
And if I used y = sin(kx)cos(wt), then dy/dt = -wsin(kx)sin(wt), and at t=0, dy/dt = 0.
If I used y = sin(kx-wt), then dy/dt = wcos(kx-wt), which doesn't have the necessary sine term.
Any ideas?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Mar24-09, 04:25 PM   #2
Recognitions:
Gold Membership Gold Member
You should take as your general solutions both sine an cosine terms:
y= sin(kx)[A sin(wt) +B cos(wt)] terms. Or equivalently work with a phase shift sin(kx)sin(wt+p).
Thread Closed
Thread Tools
Similar Threads for: Wave question - stretched string
Thread Forum Replies
Wave in a string question Introductory Physics Homework 8
Wave along the string Introductory Physics Homework 2
question about transverse standing wave including violin string Introductory Physics Homework 8
wave on string. Classical Physics 17
wave on a string Introductory Physics Homework 5
