| Thread Closed |
Building a Counter for HeartBeat |
Share Thread | Thread Tools |
| Mar24-09, 09:53 PM | #1 |
I have limited hardware components I can use for this obstacle. Lets say I have precision rectified the input heartbeat signal into a square wave... I am trying to count the number of squarewaves/heartbeats and display them on two 7-segment displays refreshing every 15 seconds...
I can only use a 4029 Up.dwn counter and a BCD driver to 7 segment display.... My issue is that the 4029 is going to need to refresh every 15 seconds however !!! the output needs to be in bpm (Beats per minute) which means it is off by a factor of 4... How can i multiply the output by 4 or is there a clever way i can do this with the timer that resets the 4029 every 15 seconds? PLEASE HELP. ive looked everywhere. even minute insight may prove valuable. thanks in advance. |
| Mar24-09, 11:18 PM | #2 |
Hey, Tenacity.
I can't help you at all; I know nothing about electronics. It does strike me, however, that this might get better participation if you have it moved to Electrical Engineering or maybe even the Computer section. |
| Mar28-09, 10:08 PM | #3 |
How about a counter that updates every second. Put your heartbeat pulse into a 64 bit shift register that shifts every 0.234 second, and you have a up-down counter that keeps track of all the "1" bits in the SR during a continously updating 15 second interval.
| Mar28-09, 10:45 PM | #4 |
huh , interesting thought, but im not sure i can use a shift register... these are the components i can use....
4011 CMOS NAND (2 input) 4029 CMOS UP/DN COUNTER 4043 RS TYPE FF 4093 SCHMITT TR NAND 4511 LED DRIVER 7 SEGMENT DISPLAY 7400 NAND (2 Input) 7402 NOR (2 Input) 7404 INVERTER 7408 AND 7410 NAND (3 Input) 7420 NAND (4 Input) 7430 NAND (8 Input) 7432 OR (2 Input) 7437 NAND (High current) 7440 NAND (High current) 7442 BCD TO 1 OF 10 DECODER 7474 D TYPE FF 7476 JK TYPE FF 7486 EXOR 7490 DECADE COUNTER 74151 DATA SELECTOR 74153 DATA SELECTOR 324 OP-AMP 339 OP-AMP 356 OP-AMP 741 OP-AMP 386 AUDIO POWER AMPLIFIER 555 TIMER RED LEDs SK3024 PNP BJT ZENER DIODE (5V) IN914 DIODE Im using the 4029 CMOS UP/DN COUNTER with the LED driver that outputs to the LED. any ideas using these components? |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Building a Counter for HeartBeat
| counter in multisim with four seven segment displays | Electrical Engineering | 6 | ||
| Velocity to jump building to building | Introductory Physics Homework | 4 | ||
| Building Geiger counter | Advanced Physics Homework | 1 | ||
| hit songs and the human heartbeat | Social Sciences | 12 | ||
| "Feel" your heartbeat | Computing & Technology | 1 | ||
