How Do You Calculate Dice Game Probabilities with Multiple Variables?
  • Context: Undergrad
  • Thread starter Thread starter brebh
    Formula Probability
The discussion revolves around calculating probabilities in a dice game involving multiple variables, specifically focusing on the number of red and blue dice, their respective scoring probabilities, and determining the likelihood of achieving a certain number of successful outcomes in a single throw. The scope includes theoretical probability calculations and practical applications for creating formulas.
  • One participant describes their problem involving calculating the probability of scoring points with red and blue dice, providing specific variables and a sample scenario.
  • Another participant suggests a method to calculate the probability by breaking it down into disjoint cases and multiplying the independent probabilities of each die.
  • A participant inquires about the possibility of creating a general formula that accommodates any number of red and blue dice and a minimum number of scoring dice.
  • A more complex mathematical expression is shared, indicating a potential formula for calculating the probabilities, though it is noted that it may be complicated to simplify further.
  • One participant expresses surprise at the complexity of the solution and indicates a desire to convert the formula into a format usable in Excel.
  • Another participant suggests that implementing the solution in Excel may require either a macro or a specific grid setup for calculations.
Participants express varying levels of understanding and approaches to the problem, with no consensus on a single method or formula being established. Multiple viewpoints and methods for calculating the probabilities are presented, indicating ongoing exploration and refinement of ideas.
Some mathematical steps and assumptions remain unresolved, and the complexity of the proposed formulas may limit their practical application without further simplification.
Individuals interested in probability theory, game design, or statistical analysis, particularly those working with dice games or similar probabilistic scenarios.
brebh
Hi!
I'm not very good with statistics and such but have been working on a problem for a month now and have finally gotten to a point where I'm ready to ask for help. I didn't really know where to go but found this forum and thought I'd give it a try here. =)
I'm working on a dice game and am looking to create a formula that I can use to plug in a few variables and have a probability of a certain result kicked back to me. Here's what I've got so far:
r = number of red dice in a single throw of all dice
b = number of blue dice in a single throw of all dice
pr = probability of "scoring a point" with a red die (1/6)
pb = probability of "scoring a point" with a blue die (3/6)
n = the minimum number of "points" desired in a single throw of all dice
To put some numbers to a sample situation... I've got 2 red dice and 1 blue die in a throw. I want to know the odds of at least 2 of the dice in the throw "scoring" (it's ok if all the dice are successful).
Rather than embarrass myself by showing you guys a formula that I know is clearly wrong, I will say that I think the result of the example I've provided should be 16.67%. I'm pretty sure that's accurate because I wrote out every combination and 36 of the 216 possible results score twice on 2 of the 3 dice.
Thanks in advance for any help and I apologize for being such a noob.
A quicker way to calculate this
If 2 out of the 3 dice score, then:
Either 2 red dice scored, and the blue die didn't score: chance of this occurring is (1/6)2*1/2 (multiply the independent probabilities of each die doing what it does)
2 red dice score, and the blue die scores: (1/6)2*1/2
1 red die scores, the blue die scores
1/6*5/6*1/2*2 - multiply by 2 because there are two ways you can pick which red die scores
Add these up to get: 1/6 as you said
The principle is you break it up into disjoint cases (so no two cases occur at the same time), calculate the probability of each case occurring, then add them up at the end. Notice if your cases overlap, then you're essentially double counting the events that occur under both cases
Thanks!
That helps for sure.
Just wondering though, is it possible to build a formula that allows me to plug in any number of red dice (r), blue dice (b) and the minimum number of dice that score in a result (n) to get the probability of different situations?
Thanks again!
[tex]\sum_{x=0}^r\sum_{y=n-a}^b\binom rx\binom byp_r^xp_b^y(1-p_r)^{r-x}(1-p_b)^{b-y}=\sum_{x=0}^r\left(\binom rxp_r^x(1-p_r)^{r-x}\sum_{y=n-a}^b\binom byp_b^y(1-p_b)^{b-y}\right)[/tex]
which with your probabilities is
[tex]\frac{1}{2^b6^r}\sum_{x=0}^r\left(\binom rx5^{r-x}\sum_{y=n-a}^b\binom by\right)[/tex]
I'm sure this can be simplified further, but it's still going to be pretty ugly.
Edit: Mathematica can get it to a single sum, but it's hideous and probably harder to calculate for any values you'd care about:
[tex]\frac{1}{2^b6^r}\sum_{x=0}^r\left(\frac{5^{r-x}b!\,_2\!\tilde{\text{F}}_1(1,n-b-x; n-x+1; -1)}{(a+b-n)!}\right)[/tex]
Edit 2: If you Google for and install Pari/GP, this will do it for you:
Code:
brebh(r,b,n)=sum(x=0,r,binomial(r,x)*5^(r-x)*sum(y=n-x,b,binomial(b,y)))/2^b/6^r
(15:32)brebh(2,1,2)
time = 0 ms.
%46 = 1/6
Holy crap!
I would have never figured that out. Thanks for the solution!
Now I need to start working on converting that into something excel can read. =)
Thanks again!
If you want to do this in Excel you'll either need to use a macro or to make a b by r grid and a calculation row beside it.
  • · Replies 41 ·
