Can the 'Almost Reimann Integral' be Recovered Using Pinsky's Textbook?
  • Context: Graduate
  • Thread starter Thread starter confinement
    Integral
The discussion centers on the challenge of demonstrating that a specific sum, S = ∑n=1 cn φn, converges to a Riemann integral as L approaches infinity. The terms φn = √(2/L) sin(nπx/L) are utilized, with the limit expressed as limL→∞n=1 √(2/L) cn sin(nπx/L). The discussion highlights the difficulty in reconciling the partition mesh Δkn = π/L with the factor √(2/L). The participant suggests consulting Pinsky's textbook, "Partial Differential Equations and Boundary-Value Problems," for further insights.
  • Understanding of Riemann integrals
  • Familiarity with Fourier series
  • Knowledge of limits and convergence in series
  • Basic concepts of partial differential equations
  • Study the properties of Riemann integrals in detail
  • Explore Fourier series and their convergence criteria
  • Investigate the implications of partitioning in calculus
  • Read Pinsky's "Partial Differential Equations and Boundary-Value Problems" for deeper insights
Mathematicians, physics students, and anyone interested in advanced calculus, particularly those working with integrals and series convergence.
confinement
I am trying to show that a certain sum rigorously tends to a Reimann integral, but I have a certain sticking point that you will find below.
[tex]S = \sum_{n = 1}^{\infty} c_n \phi_n[/tex]
[tex] \phi_n = \sqrt{\frac{2}{L}} \sin(\frac{n \pi x}{L})[/tex]
In this case the c_n can be assumed to be such that the series converges. Basically I want to show that the limit of S as L goes to infinity is a Reimann integral by definition. We have:
[tex]\lim_{L\to\infty}\sum_{n = 1}^{\infty} \sqrt{\frac{2}{L}} c_n \sin(\frac{n \pi x}{L})[/tex]
consider the function sin(k), and define a partition of the positive half of the real line by the points n pi / L. Then the mesh of the partition is pi / L. To deal with the constants define c_n = c(n pi x / L) = c(k_n). Then we have:
[tex]\lim_{L\to\infty}\sum_{n = 1}^{\infty} c(k_n)\sin(k_n) \sqrt{\frac{2}{L}}[/tex]
This is almost a Reimann integral by definition, we have an infinite sum of values of a function multiplied by something small, and the mesh of the partition of points is going to zero, the problem is that the mesh of the partition is [itex]\Delta k_n = \pi / L[/itex], not the [itex]\sqrt{\frac{2}{L}}[/itex] that I have. The constant factor is obviously not a problem, but I cannot pretend that L and sqrt(L) are the same for this purpose. Is there anyway to recover, or does this 'almost integral' correspond to anything?
Would it not be much easier to treat it like a Fourier series? :-) (Mind you, I haven't tried so I don't know)
Anywho I got a little confused when reading because you went from talking about sums of [tex]\sin(n\pi x/L)[/tex] terms to [tex]\sin(n\pi/L)[/tex], i.e. the value of the whole thing at 1. Anyway, assuming [tex]k_n=n\pi x/L[/tex] define [tex]c(k_n)=c_n\sqrt{n}[/tex], then each term in the sequence is
[tex]\frac{c(k_n) k_n^{-1/2}\sin(k_n)\sqrt{\pi x}}{L}[/tex]
which should give you an integral.. proving its existence might be tricky.. but you pays your money you takes your choice.
Try the textbook by Pinsky: Partial Differential Equations and Boundary-Value Problems
  • · Replies 16 ·
