Register to reply
Organic Naming
by 312213
Tags: naming, organic
Share this thread:
312213
#1
Mar26-09, 02:39 PM
P: 52
Name each of the following cyclic alkanes, and indicate the formula of the compound.
2. Relevant equations
3. The attempt at a solution
a. The rectangle has four corners so four carbon for butane. The branch off has two carbons so eth-. Numbering the branch C as 1, the naming is 1-ethylcyclobutane with C6H12 because each corner is 1 C plus the C written and the H comes from subtracting 4 with the number of bonds connected to each of the C. Is this correct?
b. The pentagon has five corners so five corner for pentane. The branch off is prop- and meth-. Naming starts with alphabetical order so meth- first so the prop- is three. 1-methyl-3-propylcyclopentane. Logic from a., C9H18. Is this correct?
c. Hexane from six corners. Dimethyl and ethyl here. Is this named 1-ethyl-2,6-dimethylcyclohexane or 2-ethyl-1,3-dimethylcyclohexane? C10H20.
If there is a mistake, which part?
Phys.Org News Partner Science news on Phys.org
What lit up the universe?
Sheepdogs use just two simple rules to round up large herds of sheep
Animals first flex their muscles
Mtnbiker
#2
Mar27-09, 06:44 PM
P: 5
Quote Quote by 312213 View Post
A is just ethylcyclobutane. There is no need to number the substituent, since a cycloalkane with 1 substituent will always have it at the #1 carbon. You had the formula right.
B is correct.
C is 2-ethyl-1,3-dimethylcyclohexane (you number so as to give your substituents the lowest number possible, in the absence of priority substituents such as OH). Formula is correct.
Register to reply
Related Discussions
Organic Chem - Hydrocarbon Naming Biology, Chemistry & Other Homework 2
Interactive file naming for naming multiple files in fortran90 Programming & Computer Science 2
Naming Organic Compounds Biology, Chemistry & Other Homework 1
Naming organic compounds help Biology, Chemistry & Other Homework 1
Re naming General Discussion 4
