Finding the Number of Cubes in the Middle of a Decreasing Cube Tower
  • Context: Undergrad
  • Thread starter Thread starter chewtoy929
    decreasing Numbers
The discussion revolves around finding an equation to determine the total number of cubes in a tower structure where a central stack of cubes is surrounded by decreasing layers of additional cubes. The focus is on the mathematical formulation of this problem, including the arrangement and counting of cubes in a specific geometric configuration.
  • One participant describes a tower with a central stack of "x" cubes, surrounded by decreasing layers of cubes, proposing a method to calculate the total number of cubes.
  • Another participant attempts to derive a formula by summing the cubes in each layer, suggesting a standard approach to find the sum of integers and discussing the implications of counting the center stack.
  • A request for simplification is made, indicating that the explanation may be too complex for some audiences.
  • A clarification is sought regarding the age of the person asking for simplification, suggesting that the complexity of the explanation may need to be adjusted based on the audience's understanding.
  • A participant expresses confusion about the initial answer but indicates a willingness to work through the problem independently.
Participants do not reach a consensus on the clarity of the explanation or the correctness of the proposed mathematical approach. There is a mix of understanding and confusion regarding the problem and its solution.
Some assumptions about the audience's mathematical background are present, and there is an indication that the explanation may not be suitable for all levels of understanding. The discussion also highlights the need for further exploration of smaller examples to aid comprehension.
Individuals interested in mathematical problem-solving, particularly in geometric arrangements and summation techniques, may find this discussion relevant.
chewtoy929
if you where to take something like a sugar cube stack it into a tower 6 cubes high than on each of the 4 sides stack sugar cubes in a decreasing amount so there are 6 cubes in the middle and 5 surrounding it on the four sides , then 4 surrounding that then 3, and so on. What I need is an equation for how to find a tower that has "x" amount of cubes in the middle. Any help?
So you have x cubes in the center stack, x-1 in the stack immediately to the right, then x-2, ..., on down to 1. Not counting that first stack, we have four stacks of x-1, x-2, ... cubes so that part is [itex]4\sum_{i=1}^{n-1} i[/itex]. Counting the center stack, that is a total of [itex]x+ 4\sum{i=1}^{n-1}[/itex]. There is a standard way to find that sum: it is 1+ 2+ 3+ 4+ ...+ (n-2)+ (n-1). Reverse that sum and you have (n-1)+ (n-2)+ ...+ 4+ 3+ 2+ 1. Add those two "term by term": 1+ (n-1)= n, 2+ (n-2)= n, 3+ (n-3)= n, ..., (n-2)+ 2= n, (n-1)+ 1= n. That, is each of those sums is n and there are n-1 sums. Notice that you have added the sum twice. You have to take that into account.
explain like I am 10
Are you 10? (This is important: if you are then explaining it in such abstract terms might be inappropriate.)
You gave the answer there at most 3 minutes thought. It may take you a little longer to digest than that. So try looking at it and thinking about it, perhaps by doing some smaller examples like 1 in the central tower, then 2, then 3...
no I am not it was an expression, but I don't understand the answer to the question in the first place, I think I can figure it out though, thanks.
  • · Replies 35 ·
  • · Replies 16 ·
  • · Replies 18 ·
18K
  • · Replies 35 ·
