Minimum Angular Speed to start SLIPPING BEFORE ROLLING WITHOUT SLIPPING
The discussion focuses on determining the minimum angular speed (w) required for a cylinder to start slipping before rolling without slipping on an inclined surface. The cylinder, characterized by mass (M), radius (r), and a coefficient of friction (u), is lowered onto a frictional incline at an angle (alpha). The participants explore the dynamics of slipping and rolling, concluding that if the cylinder is stationary upon contact, any angular speed would necessitate infinite acceleration, leading to slipping. The challenge lies in understanding the transition from slipping to rolling without slipping.
  • Understanding of rotational dynamics and angular speed
  • Knowledge of frictional forces and coefficients
  • Familiarity with inclined plane physics
  • Basic principles of Newton's laws of motion
  • Study the equations of motion for rolling bodies on inclined planes
  • Learn about the relationship between angular velocity and linear velocity in rolling motion
  • Investigate the effects of friction on rolling and slipping dynamics
  • Explore advanced topics in rotational kinetic energy and energy conservation in rolling motion
This discussion is beneficial for physics students, mechanical engineers, and anyone interested in the mechanics of rolling motion and frictional interactions in inclined planes.
Ransalu
Minimum Angular Speed to start SLIPPING BEFORE ROLLING WITHOUT SLIPPING.
A cylinder of mass M with radius r is given an angular speed of an w about an axis, parallel to its length , which passes through its centre. The cylinder is gently lowered onto an upward direction of inclined frictional surface which makes an angle alpha with the horizontal axis. The coefficient of friction of the two surfaces is u.
*What is the minimum angular speed w to start slipping before rolling without slipping?
*If the angular speed w is adequate to start slipping how long does it take before the cylinder starts to roll without slipping?
I can see no possible way to reach the first part of the question. I can't realize why does the cylinder slip firstly before purely rolling. Is it slipping with rolling or without rolling at the begining?
Usually you begin this kind of problem by finding the maximum up-the-hill force you can get - which is the friction force minus the component of weight down the hill. Then use F=ma to get the maximum acceleration. Alas, this problem doesn't ask for the max acceleration, but rather the max speed. If the cylinder is not moving tangentially when it contacts the surface, any w without slipping will require infinite acceleration at the moment of first contact with the surface as its speed changes from zero to rw instantly. It can't have that so it will slip.
If we interpret the "touches gently" as a cylinder that is moving in the direction uphill along the ramp just before it touches then no acceleration is required to continue moving up the ramp at that same w or rw. So it won't slip.
Note that the cylinder must use up its rotational energy to climb the hill. As it goes up, it will decelerate. I don't see how this gives us any grip on the problem, either.
Looks like an impossible problem to me, too. I will be most interested in seeing a solution!
  • · Replies 60 ·
  • · Replies 21 ·
  • · Replies 42 ·
  • · Replies 35 ·
  • · Replies 97 ·
