What Does a Strong Eigenvalue Signify in a System of Equations?
  • Context: Undergrad
  • Thread starter Thread starter LouArnold
    Eigenvalues
The discussion centers on the significance of strong (high value) eigenvalues in systems of equations, particularly in the context of ordinary differential equations (ODEs) and least squares problems. Participants explore the implications of eigenvalue magnitudes without reaching a consensus on a general statement applicable across different scenarios.
  • One participant inquires about the general significance of strong eigenvalues in systems of equations without referencing specific applications.
  • Another participant explains that in coupled ODEs, strong eigenvalues correspond to dominant eigenvectors, which dictate the long-term behavior of the system as time approaches infinity.
  • A participant provides an example involving coupled first-order ODEs, illustrating how the largest eigenvalue leads to the associated eigenvector dominating the solution over time.
  • One participant expresses understanding of the ODE context but raises a question about the significance of larger versus smaller eigenvalues in least squares problems, including singular value decomposition (SVD).
  • A later reply mentions that numerically, it is generally easier to find larger eigenvalues than smaller ones, as numerical methods often focus on identifying the largest eigenvalue first.
Participants do not reach a consensus on a general statement regarding the significance of strong eigenvalues across different contexts. There are competing views on the implications of eigenvalue magnitudes in ODEs versus least squares problems.
The discussion highlights the dependence on specific contexts, such as ODEs and least squares problems, and the potential limitations of generalizing findings across different mathematical frameworks.
LouArnold
In a system of equations with several eigenvalues, what does it mean (signify) when one is strong (high in value) and the others are weak (low in value)?
Can a general statement be made without referencing an application? If so, is there a math book that explains the idea?
If you are referring to a system of coupled ODE's then 'strong' eigenvalues correspond to the dominate eigenvectors. When I say dominate I mean ones that when time tends to infinity that the system follows a straight line given by the eigenvector.
Suppose you have two coupled 1st order ODE's which yield the general solution
[tex]{y_{1} \choose y_{2}} = \alpha {1 \choose 2} e^{4t} + \beta {3 \choose 5} e^{5t}[/tex]
So 4 is an eigenvalue associated with the eigenvector [itex]{1 \choose 2}[/itex] and 5 is the eigenvalue associated with the eigenvector [itex]{3 \choose 5}[/itex].
As time goes to infinity [itex]e^{5t}[/itex] becomes much larger than [itex]e^{4t}[/itex]. Thus we consider
[tex]{y_{1} \choose y_{2}} \approx \beta {3 \choose 5} e^{5t},[/tex]
which leads to
[tex]\frac{y_{1}}{y_{2}} \approx \frac{3}{5} \Rightarrow y_{2} \approx \frac{5}{3}y_{2}.[/tex]
In any system the largest eigenvalue will lead to its associated eigenvector dominating as time tends to infinity.
I understand the explanation in the way that it applied to ODE. The solution to the system is clear. But I was thinking of a least square problem. Whether SVD or the standard eigenvalue calculation is used, what is the significance of larger versus smaller eigenvalues?
The only thing I can think of is that, generally, it is easier to numerically find a large (in absolute value) eigenvalue than a smaller. Numerical methods typically find the largest eigenvalue, then remove that eigenvalue and apply the same method to find the next largest eigenvalue.
11K
