Thread Closed
Helicopter tail rotor thrust requirement
Share Thread Thread Tools
Mar27-09, 07:17 PM   #1
How can you calculate the amount of thrust needed by the tail rotor of a helicopter to counter the torque of the main rotor?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Mar27-09, 08:03 PM   #2
Mentor
Welcome to PF.
The answer to the question depends on what you know. If you know the horsepower and rpm of the main rotor, you can calculate the torque easily enough. More information is needed before we can help you...
Mar27-09, 08:27 PM   #3
lets say that this is for a model helicopter with .05 hp (37 watts), has blades that rotate at 300 rpm and has a 3.5 foot long tail boom. Wouldn't the required thrust of the tail rotor be cut in half if the tail boom length is doubled?
Mar27-09, 08:36 PM   #4
Making the tail boom longer would decrease the power requirements of the tail rotor.
Mar27-09, 09:00 PM   #5
Thanks, I thought it would, but how would you determine exactly how much thrust would be needed for the tail rotor at various tail boom lengths?
Mar27-09, 09:03 PM   #6
Just do a moment balance.
Mar27-09, 09:05 PM   #7
Mentor
Well, you have the horsepower and rpm. Torque is horsepower/rpm....
Mar27-09, 10:26 PM   #8
ah. So, 0.88 ft-lb would be required to counter balance to main rotor and the thrust required for the tail rotor at 3.5 feet would be 0.25 lbs, right?
Mar27-09, 10:39 PM   #9
I can tell you yes or no if you show some steps as to how you got to your final answer.
Mar27-09, 10:51 PM   #10
0.05 hp X 5252= 262.6/300 rpm = 0.88 ft-lb
0.88/3.5 ft= 0.25 lbs of thrust
Mar27-09, 11:27 PM   #11
T = 63025*hp/rpm
this "0.05 hp X 5252= 262.6/300 rpm = 0.88 ft-lb" Makes no sense to me.
I get 3lbs of thrust.
Mar27-09, 11:45 PM   #12
Quote by Cyrus View Post
T = 63025*hp/rpm
T = 63025*hp/rpm is to find torque in in-lbs, and T-5252*hp/rpm is to find it in ft-lbs..
Mar27-09, 11:49 PM   #13
Quote by PaulHP View Post
Yep you're right
Thread Closed
Thread Tools
Similar Threads for: Helicopter tail rotor thrust requirement
Thread Forum Replies
How would you determine the Lift(thrust) force of a Helicopter in hover Mechanical Engineering 20
head or tail Set Theory, Logic, Probability, Statistics 1
Integration help for helicopter rotor Calculus 5
jet planesī tail General Physics 5
helicopter rotor has four blades Introductory Physics Homework 1
