Treble and bass audio controls w/o phase shift?
Treble and bass controls in audio equipment typically utilize RC networks, resulting in a phase shift of approximately 6.6 degrees per dB of adjustment. While analog circuits inherently introduce phase shifts, active filters can be employed to selectively manage frequency ranges, albeit with some phase shift remaining. Digital solutions may offer "phaseless" adjustments, but improper design can still lead to phase issues. The discussion highlights the potential market for digital solutions that could mitigate phase shifts caused by physical speaker movement.
  • Understanding of RC networks in audio circuits
  • Knowledge of active filter design
  • Familiarity with digital signal processing (DSP)
  • Basic concepts of phase shift in audio engineering
  • Research active filter design techniques for audio applications
  • Explore digital signal processing (DSP) methods for phase correction
  • Investigate the impact of the Doppler effect on audio performance
  • Learn about the implementation of DAC and ADC in audio systems
Audio engineers, audiophiles, and anyone involved in the design or optimization of audio equipment seeking to understand phase shift implications in treble and bass controls.
Bob S
Simple treble and bass controls in audio equipment use RC networks that have a phase shift equal to a radian per neper, or about 6.6 degrees per dB of boost or attenuation. Are there analog treble or bass control circuits that have no phase shift?
Could you use active filters to pass the frequencies you want? Maybe use a high pass filter to attenuate the low frequencies and a low pass to attenuate the high frequencies.
Active crossovers still give some phase shift. The only "phaseless" boost at certain frequencies would have to be done digitally, but there are phase shifts involved there if not designed properly. Unless applying a DSP from a digital source to the next component, a DAC/DSP/ADC seems to be overkill for bass and treble only.
Still, some audiophiles might buy it, in spite of the fact that "all digital is bad", selling something that can dynamically cancel out the natural phase shift caused by woofer woofer movement ("Doppler effect") could be a big hit.
Just a matter of adding in your bass and treble controls while you are at it. :P
  • · Replies 27 ·
  • · Replies 41 ·
9K
  • · Replies 16 ·
