One two-variable, and one three-variable limits
  • Thread starter Thread starter libelec
    Limits
This discussion focuses on evaluating two limits involving multiple variables. The first limit, \mathop {\lim }\limits_{(x,y) \to (0,2)} \frac{{y^2 (x - 2)^2 }}{{x^2 (y - 2)^2 }}, reveals that using curves such as y-2=mx and y-2=kx^2 leads to infinite results. The second limit, \mathop {\lim }\limits_{(x,y,z) \to (0,1,1)} \frac{{y + 1}}{{\sqrt {z^2 - 1} }}, is approached by examining the (y, z)-plane, confirming that the limit can be simplified by focusing on \lim_{(y, z) \to (1, 1)} \frac{y + 2}{\sqrt{z^2 - 1}}.
  • Understanding of multivariable limits in calculus
  • Familiarity with curve parameterization techniques
  • Knowledge of algebraic manipulation of limits
  • Basic concepts of continuity and differentiability in multiple dimensions
  • Study the application of the epsilon-delta definition of limits in multivariable calculus
  • Learn about the use of polar coordinates in evaluating limits
  • Explore the concept of path independence in multivariable limits
  • Investigate the implications of discontinuities in multivariable functions
Students and educators in calculus, mathematicians focusing on multivariable analysis, and anyone seeking to deepen their understanding of limits in higher dimensions.
libelec
1. I need to find these two limits, without using the definition of limit:
a) [tex] \mathop {\lim }\limits_{(x,y) \to (0,2)} \frac{{y^2 (x - 2)^2 }}<br /> {{x^2 (y - 2)^2 }}[/tex]
b) [tex] \mathop {\lim }\limits_{(x,y,z) \to (0,1,1)} \frac{{y + 1}}<br /> {{\sqrt {z^2 - 1} }}[/tex]
For a) I found that if looking for the limit using curves, in this case using y-2=mx, with m=constant, and y-2=kx^2, with k=constant, are infinite.
For b) I'm clueless.
Any help will be thanked.
For the second one, note that there is no x-dependency. So you can look at curves in the (y, z)-plane and give them arbitrary x-dependency, i.e. only consider
[tex]\lim_{(y, z) \to (1, 1)} \frac{y + 2}{\sqrt{z^2 - 1}}[/tex]
Yes, I was thinking about that, thanks.
