Can a 95 CFM Fan Generate Enough Force to Move a 150 lb Object?
  • Context: Undergrad
  • Thread starter Thread starter bigbeezy
    Fan
The discussion revolves around the feasibility of using a 95 CFM fan to generate sufficient force to move a 150 lb object, considering factors such as coefficient of friction, air density, and drag coefficients. Participants explore the relationship between airflow (CFM), force, and the mechanics of moving the object, touching on both theoretical and practical aspects of the problem.
  • One participant seeks to establish an equation to determine how fast a fan producing a certain CFM can move a 150 lb object with a coefficient of friction of 0.04.
  • Another participant calculates the force needed to overcome friction, suggesting it to be 192 ft lbs based on the weight of the object and the coefficient of friction.
  • There is uncertainty regarding the conversion of CFM to foot pounds, with participants questioning the validity of such a conversion.
  • Some participants clarify that CFM stands for cubic feet per minute and discuss the need to convert CFM to a force measurement, though they express uncertainty about the correct units.
  • One participant explains that the force acting on the object involves aerodynamics and that the CFM rating alone is insufficient to determine the force exerted on the object.
  • Another participant provides a detailed calculation of airspeed and force based on fan specifications and air density, raising questions about the assumptions made in the calculations.
  • There is a discussion about the relevance of the drag coefficient and the cross-sectional area in the force calculation, with some participants debating whether the area should pertain to the fan or the object being moved.
  • One participant introduces the concept of horsepower and its potential relevance to the calculations.
  • Another participant presents a comparison of thrust generated by different fans, including detailed calculations and assumptions regarding air density and flow rates.
Participants express various viewpoints on the relationship between CFM, force, and the mechanics of moving the object. There is no consensus on the correct approach to convert CFM to force, and multiple competing models and calculations are presented without resolution.
Participants highlight limitations in their calculations, including assumptions about air density, the effects of compression, and the need for specific definitions of terms like drag coefficient and cross-sectional area. The discussion remains open-ended with unresolved mathematical steps and dependencies on various assumptions.
bigbeezy
I'm trying to see how fast a fan that produces "x" cfm can move an object that weighs 150 lbs with a cof of 0.04. How would I set up an equation to find this?
Thanks
to over come friction you haft to produce a force=(.04)n times the normal force
so f= 150(32)(.04) = 192ft lbs.
ok thanks.
one more thing, am I right in converting cfm to ft lbs?
28 cfm = 1338.96 Nm/s = 987.5 ft lbs/s
this doesn't seem right to me.
I'm sure this is obvious to everybody but me, but... what does "cfm" stand for?
cubic feet per minute , and I am not sure how to convert the whole thing
so u want to convert cfm to foot pounds per second.
yes cfm is cubic feet per minute.
I'm trying to figure out what size fan to use for a project of mine, and I am given the number of cfm the fan produces. I'm wanting to use that to figure out how fast it can propell an object. since it will take 192 ft lbs to move the object, I figured I needed to get cfm to ft lbs, but I am not sure if this would be the correct units for this.
That doesn't sound like a direct conversion to me. The fan moves a given volume of air per time, but the force actually acting on the object would involve aerodynamics. How about some more details on the project?
150 lbs normal force, .04 cof, so maximum static friction = 150 lb x .04 = 6 lbs.
The cubic feet per minute rating isn't enough to determine the force.
force = mass x acceleration = mass x (velocity change) / (unit time)
force = mass / (unit time) x velocity change
Ignoring compression effect, and assuming dry air at sea level,
1 ft^3 / min ~= 0.075 lbmass / min = .00125 lbmass / sec = .000039 slug / sec
So CFM x .000039 gives you mass flow.
The change in velocity due to the fan times the mass flow will give you the force at the fan.
Assuming no losses, and that the block captures and stops all the air, the initial force on the object (until it starts moving) will be the same as the force at the fan.
6 lbforce = Velocity_from_fan (ft / sec) x CFM x .000039 slug / sec
not sure what you mean by velocity_from_fan
think of the object as a cart and the fan(s) are mounted onboard the cart pushing air backwards, thus propelling the cart forwards. The only information i have about the output of the fan is in cfm.
just wondering... would hp be benificial in this calculation?
The force on an object from the airflow is
F = 1/2 (density of air) * (speed of air)^2 * (cross section area) * (drag coefficient)
The drag coefficient depends on the shape of the object and varies from around 1 for a flat plate, 0.5 for a sphere and perhaps <0.1 for an aerodynamic shape.
From the CFM rating of the fan and it's area you can calculate the speed of the air flow (just consider a tube of air of that volume/second going through a fan of that area)
Note that you don't care how much of the air from the fan actually hits the object assuming the air speed is constant.
Let me just see if I'm doing this correctly.
Fan specs: 95 cfm with outlet of 2-11/16 x 2-1/16 inches
Cross section area = 0.038493 ft^2
So the speed of the air would be:
95 cfm / 0.38493 ft^2 = 2467.99 ft/min = 41.1332 ft/sec
So assuming standard air density of 0.075 lb/ft^3 and drag coefficient is 1:
F= 1/2(0.075 lb/ft^3)(41.1332 ft/sec)^2(0.038493 ft^2)(1)
F= 2.4423 ft lbs/sec^2
Is this correct?
0.1N from a typical CPU fan - sounds reasonable.
Why is this? I also don't understand why the cross section area in your equation is for that of the fan and not the object. It seems to me that on a small object, a large fan would exert less force than a small fan displacing the same volume of air (at a faster velocity).
All you care about is the airspeed so the same CFM from a larger fan is a different air speed.
Think about the wind - in a gale do you really care if it a local gust or a weather front 100miles long?
Ok, so then is the cross section area in the equation of the fan or of the object?
In the drag equation it is the cross section of the object.
but in order to convert from cfm to ft/min in the fan you need the area of the fan.
95 cfm / 0.038493 ft^2 = 2467.99 ft/min = 41.1332 ft/sec
95 cfm = 1.5833 ft^3 / sec
1 lb = 1 slug ft / sec^2.
air density = .075 lbmass / ft^3 = .002331 slug / ft^3 (at about 65 degrees Farenheight)
thrust equation: force = mass flow x exit velocity (assuming initial air velocity is zero)
fan force = (.002331 slug / ft^3) (1.5833 ft^3 / sec) (41.1332 ft / sec) = .1518 lb
Compare to 1755 watt (2.35 hp), 90 mm electric ducted fan:
thrust = 6.06 lb
rotor diameter 90 mm = 3.5433 in
rotor swept area = 9.861 in ^2 = .06848 ft^2
volume_flow = velocity (ft / sec) x .06848 (ft^2)
fan force = (.002331 slug / ft^3) (volume_flow (ft^3 / sec)) (velocity (ft/sec)) = 6.06 lb
fan force = (.002331 slug / ft^3) (.06848 velocity (ft^3 / sec)) (velocity (ft / sec) = 6.06 (slug ft / sec^2)
(.002331) (.06848) (velocity^2) (slug / ft^3) (ft^3/sec) (ft / sec) = 6.06 (slug ft / sec^2)
(.002331) (.06848) (velocity^2) = 6.06
velocity^2 = 6.06 / (.002331 x .06848 ) = 37965
velocity (ft/sec) = 194.85 ft / sec
volume_flow (ft^3/sec) = 13.343 ft^3 / sec = 800.6 cfm
  • · Replies 22 ·
  • · Replies 35 ·
9K
  • · Replies 41 ·
