Graphing Hydrogen atom wave functions
The discussion revolves around graphing wave functions of a hydrogen atom using Excel. Participants express confusion regarding the variables and functions involved, particularly how to incorporate quantum numbers 'n' and 'l' into their graphs.
  • Participants discuss the need to understand the relationship between the given functions and the quantum numbers. There are inquiries about how to define variables 'a' and 'r' for graphing purposes. Some suggest converting equations into dimensionless form for easier plotting.
The conversation is ongoing, with participants sharing insights about graphing techniques and the use of Excel. Some guidance has been offered regarding the use of dimensionless variables and referencing parameters in Excel, but no consensus has been reached on the specific implementation of the functions.
Participants note a lack of familiarity with the material, indicating that some concepts may not have been covered yet in their coursework. There is also mention of uncertainty regarding how to apply the orbital quantum number 'l' in the context of the functions provided.
chart2006
I have a series of functions, states, and levels that I'm suppose to graph using excel. Only problem is I'm not even sure of what to do. I'm completely confused/lost.
n=1 l=0 [tex]R(r)=\frac{2}{a_0^{3/2}}e^{-r/a_0}[/tex]
n=2 l=0 [tex]R(r)=(2-\frac{r}{a_0})\frac{e^{-r/2a_0}}{(2a_0)^{3/2}}[/tex]
n=2 l=1 [tex]R(r)=\frac{r}{a_0}\frac{e^{-r/2a_0}}{\sqrt{3}(2a_0)^{3/2}}[/tex]
n=3 l=0 [tex]R(r)=\frac{1}{(a_0)^{3/2}}\frac{2}{81\sqrt{3}}(27-18\frac{r}{a_0}+2\frac{r^2}{a_0^2})e^{-r/3a_0}[/tex]
n=3 l=1 [tex]R(r)=\frac{1}{(a_0)^{3/2}}\frac{4}{81\sqrt{6}}(6-\frac{r}{a_0})\frac{r}{a_0}e^{-r/3a_0}[/tex]
n=3 l=2 [tex]R(r)=\frac{1}{(a_0)^{3/2}}\frac{4}{81\sqrt{30}}\frac{r^2}{a_0^2}e^{-r/3a_0}[/tex]
As for attempting this I'm not even sure of how to begin. I'd have to state some variable with excel but in this form and introducing the state of the atom into the function. What am i suppose to use for 'a' or 'r'? Will excell allow me to graph a wave function using so many undefined variables? In other words I haven't a clue as to what to do here. Any insight would be greatful.
you need to realize that h squared is the probability density and NOT the probability...
I know that h squared is the probability density and not the probability but i still don't see what the relationship is with the functions given. Maybe they are something covered in a later chapter but I don't recognize them at least from the information covered thus far. I've looked through the chapter in my book but no help. I'm still unsure as to how to graph the functions. How do I apply both 'n' and 'l' into the function in order to graph it on excel. I've come across a few other equations to solve for 'n' but nothing for 'l.' How do I implement 'l' which is the orbital quantum number into the functions? The only reason I know what 'l' even is is because I found it in 3 chapters ahead. This is by far not my strong area so I'm completely in the dark here.
A common graphing practice is to convert equations into dimensionless form, and then plot in the dimensionless variables. Hint: how can you make a dimensionless variable from a and r?
Actually, yes. You can set up a cell to contain the value of a parameter, and you can do this for as many parameters that you like. Then, in the function cells, just reference the parameters by referencing the cells. A word of caution: use the fixed reference (to do this, I think you put a "$" in front of the row number and column letter, e.g. $B$13), otherwise you may accidentally reference different cells for different instances of the function. It all depends on how much you want to learn about excel and how you decide to lay out the problem.
BTW, I will briefly mention that there is a FREE open office alternative to excel that basically works like excel ...
I will add to turin's excellent suggestion: for these plots, let "y" be a03/2 · R
So, for example, the n=1 l=0 equation is
a03/2 · R = _____?​
  • · Replies 21 ·
