Maximum magnetic field strength
The discussion centers on calculating the maximum magnetic field strength of an electromagnet driven by an oscillating current at high frequencies, specifically up to 1.5 GHz. Participants explore the application of Maxwell's equations in this context, the challenges posed by material properties, and practical considerations in electromagnet design.
  • One participant seeks to calculate the maximum magnetic field strength of an electromagnet at high frequencies, expressing frustration with the lack of practical guidance in existing literature on Maxwell's equations.
  • Another participant notes that magnetic materials are non-linear at high field strengths, suggesting that engineering texts may provide more relevant information than physics books.
  • A participant emphasizes the importance of frequency over field strength for their application, indicating a preference for materials that can handle high frequencies and field strengths.
  • Concerns are raised about hysteresis in practical materials, which can lead to energy absorption and heating at high frequencies, suggesting that vacuum may be the only effective medium at 400 MHz.
  • One participant questions the viability of superconductors for their application, seeking clarification on the applicability of simplified equations at high frequencies without a core.
  • Another participant advises that at high frequencies, a simple coil in a resonant cavity may be necessary to avoid emitting radio waves, and mentions the need for a high power RF oscillator.
Participants express differing views on the suitability of various materials for high-frequency applications, particularly regarding superconductors and the effectiveness of simplified equations. The discussion remains unresolved regarding the best approach to calculating magnetic field strength under the specified conditions.
Participants highlight limitations related to the non-linearity of materials at high field strengths, the dependence on specific material properties, and the challenges of applying Maxwell's equations in practical scenarios. There is also mention of the need for cooling solutions in high-frequency applications.
warpexplorer
Say I have an electromagnet, (that I know the dimentions, geometry, material characteristics, etc) that I am driving with a current that is oscilating at some frequency how can I calculate the maximum strength of the magnetic field that it can create at that frequency?
and the equations need to be valid for extream ranges, all the way up to say 1.5Ghz
What would be even better though, would be some real instructions on how to use maxwells equations, I could figure what I need to know from them, but I've looked through about 12 electromagnetics books and none of them did a very descriptive job a explaining them. Or answering pratical questions like "where do you find the equations that define the magnatization or polarization properties of a material you want to work with?" and almost all of them follow the equations with the words "but if we are not dealing with very large field strengths or high frequencies these equations can then simplify to ..." and they give you all the nice information about how to use those simplified equations, and they leave you in the dark about how to do anything remotly practical with maxwells equations.
any help would be greatly appriciated
Taking the second part of your questions
first, any magnetic material is non-linear at high field strengths, so that is why you are supplied with the "simplified" properties in the literature.
The building of practical magnets is more a matter of engineering, I think you may find out more from engineering texts than from physics books. Also a supplier of magnetic materials would better supply you with data on their line of materials.
You haven't given us any idea what you plan to do with the magnets so it's hard to make any concrete suggestions. ∈
yeah, I know that the're nonlinear at high field strengths, that's why I am not useing the watered down versions of those equations.
basically I want an electromagnet that changes polarity at a rate of at least 400Mhz and the highest field strength that the magnet can handle at those frequencies.
The higher the frequency and the higher the field strength the better (but frequency is worth 4 times as much to me as the field strength).
I basically just want to be able to calculate the maximum field strength of an electromagnet at a given frequency, so that i can plug in different material characteristics and see which materials will work best.
btw, when I was asking for an explanation about maxwells equations, I wasnt asking for specific applications, a completely general explanation would be fine, like "to find the magnetic field strength, take this constant multiply it by the permiability equation for the material then multiply it by the current density in the conductor, and intigrate it over the surface of the conductor" (of course that's not correct, just an example), but somthing as simple as that would work
The only "material"
that will work at 400mhz is vacuum. Futhermore any practical material has a property called hysteresis which means it absorbs energy whenever the field changes, which causes heating propertional to frequency. To get high field strengths you may need to use water cooled copper tubing and fiberglass construction to hold the coils together, and forget about any core material.
Having just read this
You can see that the materials available won't work at 400Mhz, you just do the calculations for a vacuum.
would superconductors work well for what i want? say maybe a 0.5 T at 800Mhz?
will just the plain watered down equations work at high frequecies and field strengths if I don't have a core? :)
btw, thanks for you input :)
NO, superconductors won't work,
In a practical application at those frequencies you'll probably want to use a simple coil in a resonant cavity, otherwise you'll emit radio waves. You'll need a high power RF oscillator to generate the field strengths you want. You can find good information on that in radio engineering books.
  • · Replies 41 ·
  • · Replies 198 ·
17K
  • · Replies 16 ·
  • · Replies 43 ·
