Cost Comparison of 200KW Induction Motors
The discussion revolves around the cost comparison of two 200KW induction motors operating at different voltage levels (400V and 1KV). Participants explore various aspects of cost-effectiveness, including purchase, installation, and operational costs, as well as efficiency considerations.
  • Some participants suggest that the cost-effectiveness of the motors depends on the voltage of the available three-phase supply.
  • One participant notes that the 1KV motor may dissipate less power as heat due to lower current, potentially leading to higher efficiency and lower operating costs, provided a 1KV supply is available.
  • Another participant raises the question of whether cost-effectiveness refers to purchase, installation, or running costs, indicating that these factors depend on different circumstances.
Participants do not reach a consensus on which motor is more cost-effective, as various factors influence the decision, and multiple competing views remain regarding the implications of voltage on cost and efficiency.
Limitations include the dependence on the availability of specific voltage supplies and the need for further clarification on what aspects of cost-effectiveness are being considered (purchase, installation, or operational costs).
wkaiyu
Hello,
If I have two induction motors, both rated power are 200KW. One is based on 400V input, and another is 1KV input. Which one will be more cost effective? How much the cost difference could be?
Thanks.
I believe that the answer would depend on the voltage of the available 3 phase supply that you have to power the motor.
wkaiyu said:
Hello,
Thanks.
Cost effective to purchase? Cost effective to install? Cost effective to run? They are all different things that depend on different circumstances.
Since P=I^2R, the 1KV one will dissipate less power in the windings in the form of heat. This means more energy is conserved and higher efficiency is achieved. The 1KV motor may also be able to have smaller conductors feeding it. Usually the higher the voltage, the lower the operating costs. Obviously this only works if you have a 1KV supply available.
can u explain about DC Motor and its uses
  • · Replies 51 ·
  • · Replies 18 ·
  • · Replies 22 ·
