Why Does the Sun Look Yellow When Paper Looks White?
  • Context: High School
  • Thread starter Thread starter Tyger
    Paper Sun The sun
The discussion revolves around the perceived color of the Sun compared to the color of a white piece of paper when exposed to sunlight. Participants explore the reasons behind the Sun appearing yellow while paper appears white, considering factors such as light scattering, background effects, and the spectral characteristics of sunlight.
  • Some participants suggest that a piece of paper appears white because it reflects a combination of all colors, while the Sun emits more yellow light than other colors.
  • One participant notes that the perceived color of the Sun may depend on the background against which it is viewed, such as a blue sky or a black sky.
  • Another viewpoint indicates that the Sun's light spectrum resembles that of a black body at approximately 5,800 Kelvin, with a peak intensity in the visible spectrum that is close to yellow.
  • Some argue that the scattering of blue light in the atmosphere contributes to the Sun appearing yellow, as the blue light is scattered away before reaching our eyes.
  • There is a mention of the human eye's sensitivity to different colors, suggesting that this may influence the perception of the Sun's color.
  • One participant points out that when a piece of paper is placed in different lighting conditions, such as shade or direct sunlight, its color appearance changes, indicating the influence of surrounding light.
Participants express multiple competing views on why the Sun appears yellow and how background and atmospheric conditions affect color perception. The discussion remains unresolved, with no consensus reached on a single explanation.
Some claims rely on assumptions about light scattering and human color perception, which are not fully explored or agreed upon. The discussion includes various interpretations of the spectral characteristics of sunlight and the conditions under which colors are perceived.
Tyger
When you hold a piece of paper up to sunlight it looks white. But when we look at the Sun it looks yellow. Who's first with the answer?
Science news on Phys.org
Could it be because a piece of paper is made out of
a whole bunch of stuff so we get the combined white color ?
the yellow light is being reflected away from your eyes so you don't see it.
I am not sure, but i guess that :
White color is an equal 'mix' of all the 7 colors of the rainbow.
The sun does not emit an equal mix, it emits more yellow than other colors (but eventually it emits all colors).
So you can say that the sun light emits white+yellow, and your paper seems to reflect yellow away (like what sheldon said), so only white reaches ur eye.
I don't recall ever looking at the Sun and seeing yellow. The light from the Sun has a spectrum which is very much like that of a black body at a temperature of about 5,800 Kelvin. The peak of the plot of intensity vs. wavelength shows a peak aroung the middle of the visible spectrum and is about constant throughout the visble spectrum with the max at about yellow. But it's not that different. The fact that aa piece of paper looks white is a demonstration of that fact since a white piece of paper reflects all colors. Take the "white" piece of paper and place it under Sunlight - it looks white. Now place it under a incandescant lamp - it looks yellow.
Pmb
the color the sun looks probably depends
on the background you see it against
standing on moon, sun against a black sky-----looks white
against a blue sky-----yellow (Y and B are complementary colors)
coming thru cloud or fog it would be against a neutral gray or white background-----would look white
the light, separated out from any background effects, would
analyze out to be pure white
people's color sense has contrast with background built in
so complementary colors have something to do with how
colors look---there could even be an evolutionary reason
for this, some kind of foodgathering or survival thing---never
thought about it
There've been enough guesses on this one
that I think an answer is in order. I was going to post this earlier but someone put up a thread about why the sky was blue, and that was too much of a hint. But that is why, the sun looks yellow because the blue light is scattered out before it hits our eyes. But when we hold a piece of paper up to the sky, it recives the scattered blue light as well as the yellower sunlight. If you put the same piece of paper in the shade it will have a distinct blue cast. Likewise if you shield it from skylight but let the sunlight hit it, it will look yellowish.
But isn't lamda max for 5800 K in between yellow and green? And due to scattering and also that our eyes are more sensitive to yellow, that we then perceive the sun as yellow?
And to answer the original question, you are seeing light shinig through the paper.
P.S. Tyger we are waiting for you to go on the physics Q&A game
Don't forget that our eyes and brain compensate for a lot of factors. That is one reason many people have trouble learning photography, they don't make allowance for the camera's stupidity in that respect. So our eyes see sunlight as white, even though it doesn't fit the abstract definition of "white light".
  • · Replies 207 ·
16K
  • · Replies 40 ·
  • · Replies 66 ·
  • · Replies 22 ·
