N-doped region tend to flow to the p-doped region
  • Thread starter Thread starter Harmony
    Flow
The discussion centers on the behavior of electrons in n-doped regions of diodes, specifically their tendency to flow to p-doped regions due to the diffusion effect. A depletion region forms until the electric field within it counteracts this diffusion, establishing equilibrium. However, a minimum forward bias voltage of approximately 0.3-0.5 V is necessary to overcome the built-in potential that opposes current flow, allowing the diode to conduct. This understanding clarifies the relationship between diffusion, electric fields, and the required forward bias in diode operation.
  • Understanding of semiconductor physics
  • Knowledge of diode operation principles
  • Familiarity with depletion regions in p-n junctions
  • Basic concepts of forward bias and built-in potential
  • Research the current-voltage characteristics of diodes
  • Study the effects of temperature on diode performance
  • Learn about the role of built-in potential in semiconductor devices
  • Explore the differences between ideal and real diodes
Electrical engineers, semiconductor physicists, and students studying electronics who seek to deepen their understanding of diode behavior and semiconductor junctions.
Harmony
When a diode is first manufactured, the electrons in the n-doped region tend to flow to the p-doped region due to diffusion effect. In the process, a depletion region is formed until the electric field in the depletion region cancel out the diffusion effect. Hence an equilibrium is reached. (or so I thought)
However, since this two effect cancel out each other exactly, why would we need a minimum voltage of about 0.3-0.5 V to forward bias it? Wouldn't any voltage cause current to flow, since the diffusion+external voltage source is now greater than the electric field in the depletion zone alone?
You're correct in that a depletion region is formed, and that a "built-in" potential across the depletion region results, but incorrect in the ramifications of this. The built-in potential opposes the direction of current flow as it normally occurs when the diode is acting in forward-bias mode.
So you need to overcome the built-in potential (the forward diode voltage) before the diode turns on and current starts flowing:
http://en.wikipedia.org/wiki/Diode#Current.E2.80.93voltage_characteristic
17K
