Register to reply
Diesel generator and capacitor question
by generaors1234
Tags: capacitor, diesel, generator
Share this thread:
generaors1234
#1
Apr2-09, 05:59 PM
P: 1
I am currently designing a water distribution system to be installed in Honduras and have run into a small problem. We plan on using a 1.5hp pump which runs at 115 v and 17 amps but the startup requires 106 amps. So to run the pump we need a 2kW diesel generator but to start we need at least a 12.5 kW generator and were told a solution to our problem might be using a capacitor and a smaller sized generator. The problem is that we don't really understand much about capacitors and were looking for any help you might be able to give such as what size and type of capacitors we might need. Thank you for your time.
Phys.Org News Partner Engineering news on Phys.org
Philips introduces BlueTouch, PulseRelief control for pain relief
3-D printing leads to another advance in make-it-yourself lab equipment
Nanoscience makes your wine better
Bob S
#2
Apr2-09, 07:38 PM
P: 4,663
You need to use a capacitor-start single phase motor. Their locked-rotor amps for a 1 1/2 HP motor is about 90 amps (1800 RPM) or 80 amps (3600 RPM). At one time, there were repulsion start electric motors available, which used less starting amps, but they are no longer available. A flywheel on your generator will help. You should base the generator size on surge current rating, as well as continuous current rating.
Usually water pumps require less starting torque (and amps) than water pumps, so you may not need the locked-rotor amp rating on the generator..
Averagesupernova
#3
Apr2-09, 07:53 PM
P: 2,537
Do a search on soft-start devices for single phase motors.
Dr.D
#4
Apr2-09, 10:16 PM
P: 619
Bob S: Did you mean to say something else here: "Usually water pumps require less starting torque (and amps) than water pumps, so you may not need the locked-rotor amp rating on the generator.."? This is double talk.
Bob S
#5
Apr3-09, 12:45 PM
P: 4,663
Quote Quote by Dr.D View Post
Sorry. I meant to say
"Usually water pumps require less starting torque than air compressors, so you may not need the motor locked rotor rating on the generator."
I am basing my estimates on the Emerson motor catalog: http://www.emersonmotors.com/products/ecatalog.htm
uart
#6
Apr3-09, 02:06 PM
Sci Advisor
P: 2,751
The actual generator part of the "diesel generator" may be able to handle a significant short term over-current. Some it may even be possible to get away with just using a big enough flywheel on the diesel.
Other than that I second the soft-start idea. Really that would be the best approach IMHO
Dr.D
#7
Apr3-09, 02:06 PM
P: 619
Quote Quote by Bob S View Post
That is entirely believable. For the water pump, you don't have any losses during starting except flow losses through the valves. For the compressor, you have to begin compressing gas, which while it is not "lost energy" it is "stored energy" so it is temporarily lost at a time when you really can't afford to lose any energy from the system, i.e. during starting.
Register to reply
Related Discussions
RCL circuit containing only a capacitor, inductor, and generator Introductory Physics Homework 14
Flywheel Generator - Split from Propane Solar Collector/Generator Thread Mechanical Engineering 52
Diesel Engines - Power question Engineering, Comp Sci, & Technology Homework 0
Frequency of Generator + V of Capacitor Introductory Physics Homework 2
DC generator question please help... Engineering, Comp Sci, & Technology Homework 7
