Thread Closed
Unable to find the nonlinear least squares
Share Thread Thread Tools
Apr4-09, 12:53 AM   #1
We have the following x, y values
x ||| y
1.0 -0.15
1.5 0.24
2.0 0.68
2.5 1.04
3.0 1.21
3.5 1.15
4.0 0.86
4.5 0.41
5.0 -0.08
How can you find the equation
[tex]y(x) = ax^2 + bx + c[/tex]
by least squares?
3. The attempt at a solution
I know how to calculate the equation for a line by solving
Ax = b
taking transposes of A at the both sides
[tex]A^TAx = A^Tb[/tex]
and then solving for x.
My second attempt
I made a 9 x 3 matrix for A where the first two columns are ones, 3 x 1 for x and 9 x 1 for b.
However, I get a singular matrix for
[tex]A^TA.[/tex]
Apparently, my method is not right.
I could make 3 equations such as
y(0), y(1) and y(2)
and solve for a, b and c.
However, I see that the method is not least squares and also rather inaccurate, since
not all points are considered.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Apr4-09, 05:54 AM   #2
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
To find [itex]y= ax^2+ bx+ c[/itex] that gives the best fit, the equation you are trying to solve is AX= Y:
[tex]\begin{bmatrix}x_1^2 & x_1 & 1 \\ x_2^2 & x_2 & 1\\\cdot & \cdot & \cdot \\\cdot & \cdot & \cdot \\ \cdot & \cdot & \cdot \\ x_n^2 & x_n & 1\end{bmatrix}\begin{bmatrix} a \\ b \\ c\end{bmatrix}\begin{bmatrix}y_1 \\ y_2 \\\cdot \\\cdot\\\cdot \\ y_n\end{bmatrix}[/tex]
Multiplying by the transpose of A on both sides gives an equation with a 3 by 3 matrix you can solve:
[tex]\begin{bmatrix} \sum x_i^4 & \sum x_i^3 & \sum x_i^2 \\ \sum x_i^3 & \sum x_i^2 & \sum x_i \\ \sum x_i^2 & \sum x_i & n\end{bmatrix}\begin{bmatrix}a \\ b \\ c\end{bmatrix}= \begin{bmatrix} \sum x_i^2y_i \\ \sum x_iy_i \\ \sum y_i \end{bmatrix}[/tex]
Apr7-09, 08:58 AM   #3
Quote by HallsofIvy View Post
Let your columns to be A1, A2 and A3, respectively for the first, second and third columns.
Is it wrong to write the columns as A3, A2, A1?
I have always set the column with the lowest degree to be the first column, and
so on.
Thread Closed
Tags
matrix least-squares
Thread Tools
Similar Threads for: Unable to find the nonlinear least squares
Thread Forum Replies
Nonlinear least squares problem General Engineering 0
fundamental question unable to find answer Introductory Physics Homework 4
Numerical Methods - Linear Least Squares, Non-Linear Least Squares, Optimization Calculus & Beyond Learning Materials 0
numerical solutions of system of nonlinear algebraic equations nonlinear algebraic eq General Math 6
z scan technic to find nonlinear coefficient General Physics 0
