| Thread Closed |
Electric Potential (charged conducting sphere) |
Share Thread | Thread Tools |
| Apr5-09, 02:25 PM | #1 |
A 33 -cm-diameter conducting sphere is charged to 457 V (relative to a point an infinite distance from the sphere where the potential is zero). a. What is the surface charge density σ? 2. Relevant equations Surface Area= 4(pi)r^2 Surface Charge Density= Q/A V=kQ/r 3. The attempt at a solution So initially I found the surface area (it's 3421.1944 cm^2) and then divided the electric potential by that. This is obviously wrong. Then, I used the formula for electric potential and solved for Q to get the charge of the sphere. I got 8.388x10^-9 C. I think I may have done something wrong because my units didn't cancel out quite right, but I didn't think too much about it. I then plugged this into my formula for surface charge density, and got 2.452x10^-10 C/m^2. My answer is supposed to be in uC/m^2 so I multiplied the answer by 10^6 and got 2.452x10^-4 uC/m^2. I put this into the answer box, and it is wrong. So thenI thought maybe I plugged in the wrong distance before (I used the radius of the sphere and not the diameter though i'm sure the radius is correct) and did the same as above, and ended up with 4.412x10^-3 uC/m^2. So right now, I'm simply at a loss as for what I'm doing wrong. I'd like to note that I'm in an algebra-based physics class for a reason- calculus is lost on me, I'm sorry. 1. The problem statement, all variables and given/known data 2. Relevant equations 3. The attempt at a solution |
| Apr5-09, 02:53 PM | #2 |
Recognitions:
First of all maybe express your total charge in μC.
V = kQ/r Q = V*r/k = 457*.165/9*109 = 8.37*10-9C = .008378 μC |
| Apr5-09, 02:59 PM | #3 |
Did I change units wrong? to go from Coloumbs to μC you would multiply by 106, right? EDIT: I just tried that and I come up with the same answer. |
| Apr5-09, 03:07 PM | #4 |
Recognitions:
Electric Potential (charged conducting sphere)So you can convert 10-6 to μ, yes. |
| Apr5-09, 03:10 PM | #5 |
Recognitions:
| Apr5-09, 03:18 PM | #6 |
| Apr5-09, 03:31 PM | #7 |
Ah- I got it now, I was converting my cm2 to m2 wrong. I've got the answer now, thank you!
| Apr5-09, 03:42 PM | #8 |
Recognitions:
Good luck. |
| Apr5-09, 04:26 PM | #9 |
Thanks again. |
| Thread Closed |
| Tags |
| electric potential, potential energy, sphere, surfacechargedensity |
| Thread Tools | |
Similar Threads for: Electric Potential (charged conducting sphere)
| Electric potential inside non-conducting sphere | Introductory Physics Homework | 4 | ||
| Electric Potential at Center of Uniform Conducting Sphere? | Introductory Physics Homework | 4 | ||
| Charged ring inside a conducting sphere. | Introductory Physics Homework | 1 | ||
| Change in Electric Potential from the Surface of a Conducting Sphere to Infinity | Introductory Physics Homework | 4 | ||
| Charged conducting sphere in a uniform electric field? | Advanced Physics Homework | 0 | ||
